Hi all
Hope that this is the right forum for this question.
I have an Intel DP55KG motherboard. I was using onboard sound until I ran into the volume fluctuating problem. The problem is that when playing mp3, mp4 or even flash video, the volume rises and lowers at random. It doesn't matter which player I use, the problem persists. After getting flustered, I installed a Asus Xonar, but the problem persists. Anyone have any ideas?
System is Windows 7 with 16 GB Ram.
Brainiac
From the Control Panel select the Sound applet. On the Playback tab select the playback device you are using (speakers, HDMI, whatever). Press the Properties button. Go to the Enhancements tab. Look to see if Loudness Equalization is enabled. Try disabling all effects. Etc.
Thanks for the reply but that did not fix things. I had to disable the NVidia High Definition Audio Device.
Brainiac
C00D11B1 error, MP3 music file now playing video!!!
By mayonez in forum AudioReplies: 8Last Post: 17th Jun 2010, 11:06 -
Can Windows Movie Maker capture photos while playing video?
By coody in forum Capturing and VCRReplies: 2Last Post: 5th Aug 2009, 22:09 -
Weird problem with ----- video for windows/codec/playing/or i don't know
By RYGER in forum Software PlayingReplies: 11Last Post: 7th Sep 2008, 21:03 -
Playing Captured Video in Windows
By Conroe in forum Newbie / General discussionsReplies: 11Last Post: 15th Aug 2008, 17:57 -
How to stop audio/sound mp3 file from playing when video is finished playin
By lindylex in forum ProgrammingReplies: 3Last Post: 14th Mar 2008, 18:36
