Closed Thread
Results 1 to 9 of 9
    Jul 2012
    New Brunswick, CA
    hopefully I'm posting this in the right forum..
    I'd like to record gameplay footage on top of myself speaking and my friends speaking through a skype call
    I have the "what u hear" option on my recording tab, and recording with that works fine, however once I set it to what u hear, my friends hear all my computer sounds through the skype call.
    anyone know a solution to this problem? I'd like to be able to record in the "what u hear" mode without broadcasting my computer sounds through skype.
    if I could somehow select "what u hear" option for my computer and the microphone option for skype, that might work, but I can't figure out how to do that (if it's even possible).
    here are my audio settings if it helps:
    Jul 2012
    New Brunswick, CA
    bump
    Jul 2012
    New Brunswick, CA
    what an amazing and helpful forum this is. glad I found it!
    Aug 2006
    Let me give you a clue, since you appear not to have one. Bumping your topic after less than 24 hours is not only against the forum rules, it makes you look childish. Insulting the people who might help you with sarcastic comments is not likely to get you any help. Your question is related to Skype. Try a Skype forum.
    Jul 2012
    New Brunswick, CA
    lol well first you can check the dates I created the thread on the 26th, bumped on the 27th and then again on the 28th, so idgaf, and plus this problem is hardly related to skype, it's more so related to the fact that my recording options is inputing wave + mic instead of just mic, and if you don't think that's related to audio then you can go **** yourself you ******* retard
    plus I solved the ******* problem so you can say whatever the **** you want
    Aug 2006
    Wow, emotionally unbalanced and childish. LOL
    Jul 2012
    New Brunswick, CA
    I'm surprised you're actually taking the time to reply to this thread
  8. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    All this drama over recording a video game that millions of other people also own? Don't tell me....you play it better than ALL the other millions....right?
    canada
    Thread closed.
