Hi all,
I'm new to the forum and unsure where to post this so many apologies if this is in the wrong section. I've muxed a 5.82 GB MKV file with tsMuxeR (version 1.10.6), inserting my own custom chapters, selecting my output as AVCHD and then burning the resulting folders onto a Verbatim DVD+R DL disc. The problem is that my blu-ray players only recognise the first chapter, the video however plays perfectly all the way through. I've been successful in creating many AVCHD discs before with smaller MKV files, also inserting custom chapters and burning onto Verbatim DVD+R SL discs. Does anyone know if I should be doing anything differently when using DLs? Any help would be much appreciated.
Many thanks
Do the chapters work when you play it on your computer? Don't burn it unless you check on computer first. The chapter setting is on the Blueray tab. Try burning as BR,not AVCHD.
Use multiavchd to author your mkv files,much easier to set chapters.
I was unaware that such a file existed but will now know what to check before burning, many thanks! Only the first chapter was listed in the 00000.mpls file so I have concluded that I must have entered the chapters wrongly somehow. I've muxed the file again as a BR and AVCHD and noticed that all custom chapters were listed in the 00000.mpls file. All chapters worked when playing on my computer so I burned the BR and AVCHD and they were perfect, thanks. Thanks for recommending multiAVCHD too, looks like this may be useful for burning multiple MKV files onto one disc, which I may do in future.
Thanks again guys, all help much appreciated!
How to create custom Chapters in: H.264 MP4 (no audio track)
By cpcmfan in forum EditingReplies: 4Last Post: 17th Jun 2012, 18:30 -
Creating an episode DVD with custom chapters
By Shinsui in forum Authoring (DVD)Replies: 3Last Post: 10th Aug 2010, 12:32 -
Can't control custom chapter list of tsmuxer.
By wisitch in forum Authoring (Blu-ray)Replies: 1Last Post: 26th Mar 2010, 03:08 -
Problem with tsMuxeR...
By hiimbored in forum Authoring (Blu-ray)Replies: 8Last Post: 6th Oct 2009, 03:43 -
Makeing DVD from avi. with Custom Chapters
By Eternal7331 in forum Authoring (DVD)Replies: 7Last Post: 18th Jan 2008, 20:31
