Closed Thread
  1. I am trying to edit my TS file with avidemux, The codecs are MPEG-2 and ACC 2. the problem is that the audio becomes out of sync. I discovered this is because the bitrate for the audio is variable. In order to keep the audio and video in sync I need to make a VBR Time Map in avidemux. In order to do that I need to have MAD (MPEG Audio Decoder: http://www.underbit.com/products/mad). I think that I have it because when I go to Help -> Plugins in avidemux, under the audio tab it says LibMad Decoder Plugin for avidemux (c) mean. Maybe that isn't the right one, or it's not enabled, I really don't know, but it won't make a VBR Time Map and I don't know what to do.
    Here are the specs of the video:
    General
    Complete name : C:\Users\User\Desktop\Video (CX 1440x1080 MPEG2 AAC).ts
    Format : MPEG-TS
    File size : 3.55 GiB
    Duration : 30mn 29s
    Start time : UTC 2012-04-07 09:54:33
    End time : UTC 2012-04-07 10:24:58
    Overall bit rate : 16.7 Mbps
    Network name : 4XEl9-0h4
    Video #1
    Menu ID : 1056 (0x420) / 1057 (0x421) / 1058 (0x422)
    Format : MPEG Video
    Format version : Version 2
    Format profile : Main@High
    Format settings, BVOP : Yes
    Format settings, Matrix : Custom
    Codec ID : 2
    Duration : 30mn 29s
    Bit rate mode : Variable
    Maximum bit rate : 24.0 Mbps
    Width : 1 440 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate : 29.970 fps
    Standard : Component
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Interlaced
    Scan order : Top Field First
    Compression mode : Lossy
    Color primaries : BT.709
    Transfer characteristics : BT.709
    Matrix coefficients : BT.709
    Video #2
    Menu ID : 1440 (0x5A0)
    Format : AVC
    Format profile : Baseline@L1.2
    Format settings, CABAC : No
    Format settings, ReFrames : 2 frames
    Format settings, GOP : M=1, N=30
    Codec ID : 27
    Duration : 30mn 27s
    Bit rate mode : Constant
    Nominal bit rate : 219 Kbps
    Width : 320 pixels
    Height : 180 pixels
    Frame rate mode : Variable
    Color space : YUV
    Bit depth : 8 bits
    Scan type : Progressive
    Audio #1
    Format : AAC
    Format profile : LC
    Muxing mode : ADTS
    Codec ID : 15
    Duration : 30mn 29s
    Bit rate : 192 Kbps
    Minimum bit rate : 127 Kbps
    Maximum bit rate : 270 Kbps
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Delay relative to video : -147ms
    Stream size : 41.9 MiB (1%)
    Audio #2
    Format : AAC
    Format profile : HE-AAC / LC
    Muxing mode : ADTS
    Codec ID : 15
    Duration : 30mn 29s
    Bit rate : 48.0 Kbps
    Minimum bit rate : 15.4 Kbps
    Maximum bit rate : 153 Kbps
    Sampling rate : 48.0 KHz / 24.0 KHz
    Delay relative to video : -149ms
    Stream size : 10.5 MiB (0%)
    For more info see my previous post: https://forum.videohelp.com/threads/347941-Help-editing-TS-file?p=2176247#post2176247
    canada
    Please do not cross post,one thread is enough,this thread is closed.
