Using many guides already available on the internet I found the following steps to region-unlocking my Phillips DVDR615 DVD Player / Recorder:
Or some variations on that theme. It seems that when you hit 'play 159' or '159 play' it should show some dashes where you can enter the unlock code (121212005255) But I never seem to be able to get the dashes. I tried doing it really quick from the start, or later when fully booted. Connected to TV and disconnected...etc.
- Turn on the player from the front panel (without a disc inserted)
- Press TUNER or the blue button (or open the HDD browser)
- Press PLAY
- Enter 159 121 212 005 255
- Press PLAY
- Turn the player off
What am I doing wrong?
Unlock instructions here for Philips players are notorious for being not 100% correct. For example, you might look at the instructions to unlock the DVP3560. The later instructions are correct. The earlier ones are slightly wrong.
The unlock instructions we have say the following:
1.On
On remote:
2.Tuner
3.Play
4.159
5.121212005255
6.Play
7.Standby
Note that DVD recorders usually can't be unlocked and depending on how old your is, there is some chance that Philips changed the hardware and/or firmware on it from earlier ones and the hack no longer works.
Thanks for your reply. Does it say anything about the timing of the first steps? If I turn it on, it just goes to 'no signal TV' and pressing 159 simply 'tries' to switch the channel 3 times.
LOL.
Press buttons FASTER.*** Now that you have read me, do some other things. ***
Unlock region on LG BD670
By Pebeto in forum DVD & Blu-ray PlayersReplies: 10Last Post: 24th Aug 2012, 08:02 -
Need region unlock for LG HX996TS...
By mausinho in forum DVD & Blu-ray PlayersReplies: 8Last Post: 26th Dec 2011, 11:45 -
Help ! Panasonic BD-60 UNLOCK DVD region code (Region 1)
By aexp in forum DVD & Blu-ray PlayersReplies: 2Last Post: 3rd Sep 2009, 11:24 -
Region Code Unlock for LG DR 4800 ?
By carletto in forum DVD & Blu-ray RecordersReplies: 2Last Post: 12th Jul 2009, 12:04 -
How can I unlock the dvd region
By roUndy_sh in forum Video ConversionReplies: 8Last Post: 11th Jun 2009, 01:20
