Results 61 to 62 of 62
The crop had little to do with encoding time - unless you want to count the time it takes filters and encoders to fiddle with 12 pixels of head-switching noise in each frame. So I guess you could say it helped, if only a little. Actually, it was at the top so that I could use a histogram without the borders interfering. So I just left it there. But as manono has noted, adding borders early and then making color/levels changes can change the "black" of the border. So you might want to use after any ColorYUV or Tweak work, etc. In the video I made, the borders were remasked anyway in TMPGenc.
Other than removing head switching noise, the crop centered the image. You wouldn't want to leave it cropped that way thru the script: many plugins work only with mod-16 or mod-8 frame sizes.
Hmm, I see we have questions . . .
No, the script treats the video as progressive. "Input_Type=1" is for progressive video, not interlaced. That input mode is designed to help repair botched deinterlace jobs, which is what that clip is. The genius who performed that deinterlace went so far as to use a method that discards half the original fields and then used some kind of field-blending technique (NOT recommendeed!). There is no deinterlace statement or processor in the script.
It's 30 fps, not 60.
I ran the script in 2 steps. OK with me, my script was just a suggestion. There are dozens/hundreds of ways to do it. The operative word here is "script", not "scripture". (
pun intended).
Keep or modify any change at will. I got better results with NeatVideo anyway, but I usually refrain from suggesting filters that users don't have. Looked somewhat better, but it still didn't fix all the problems.
Ok with me, it's your choice. Medium softens more.
The fine grain added with low settings of AddGrainC is too fine to cover spots. It was added to help debanding and deblocking. RemoveSpots also helps smooth contour shimmering and to stabilize rapidly shifting chroma noise patterns. Invisible grain? This is the first I've heard of it. It doesn't really mask noise, it just gives the impression of softer blended edges. The technique is also used by DeBlock and DeBlock_QED. but in a different way.
There is no flicker in the clip. Even if there were, TemporalSoften won't fix flicker. I think you might mean "flutter". TemporalSoften was used to smooth some of the wiggles and the shifting macroblocks and banding, which is what you refer to as flicker. TemporalSoften like most temporal smoothers does soften somewhat, which is why I used a low setting. It also helps a bit to calm the hard-edge look of exaggerrated highlights (look at the announcer).
TemporalSoften isn't a plugin. It's an Avisynth built-in.
TemporalSoften works only in YUY2, the others (except QTGMC) are YV12 only. I don't see that it would cause problems.
You can turn deblock on in MCTemporalDenoise (at medium it's off by default) and set any strength you want. DeBlock is faster and stronger than QED. The "CPU" parameter you mentioned isn't that strong unless you set it that way, but every bit helps.
Macroblocks and banding are big problems in this clip. Deblockers are usually specialized smoothers of one kind or other.
It's explained in the documentation for FFT3D. Think of it as a strength setting. The higher, the more it repairs, and the more it blurs. Very high values can produce fog effects.
EEDI2 is partly an anti-alias filter. I think it's better with anime. Because I switch MCTD settings a lot, I leave EEDI2 = false. If it's already false in the defaults, leaving it there won't matter.
Higher values are up to you. It sharpens everything, including grain. The default is 100.
I used settings that seemed to get some desired results. With damaged sources that are more noise and abuse than they are actual video, MCTD can be very aggressive. I tried "high" at first (results were way too soft, and most problems were still there), then "medium" (too soft), and settled on Low with some defaults turned on. The best way to tweak and learn MCTD is to just use it. You can always apply it lightly and then try to address some remaining noise with other plugins, or set it high and use other filters to recover some detail. But the biggest problem with this clip is that somebody found so many ingenious ways to mess it up.
If speed is your top priority, go for it. Some of this video's damage can't be fixed with the tools available to us peasants. at any speed. We just do what we can with the tools we have.Last edited by sanlyn; 23rd Mar 2014 at 10:09.
Best quality and speed video denoisers 2011
By mammo1789 in forum RestorationReplies: 146Last Post: 8th Apr 2013, 07:01 -
how do I convert a video that shows square pixels to no pixels?
By sxpredman in forum Newbie / General discussionsReplies: 4Last Post: 10th Jan 2010, 03:56 -
Another question: Converting square pixels into round pixels.
By Earthling2000 in forum Newbie / General discussionsReplies: 13Last Post: 23rd Nov 2009, 11:20 -
Remove ads, subs and audio that I don't need and modify buttons
By Brent.M in forum DVD RippingReplies: 8Last Post: 13th Aug 2008, 11:38 -
denoisers comparisons
By cd090580 in forum RestorationReplies: 17Last Post: 12th Mar 2008, 14:14
