Results 1 to 28 of 28
  1. I need to edit my .ts file. The codecs are Mpeg-2 and ACC. What is the best program to use for that?
  2. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    AviDemux is my first choice to edit almost anything.
  3. Do you know if it supports .TS files though?
  4. It doesn't say Mpeg-2 though.
  5. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    I use it to edit these:
    Complete name : G:\JH Raw\REC_00[remux].ts
    Format : MPEG-TS
    File size : 3.01 GiB
    Duration : 1h 7mn
    Overall bit rate : 6 346 Kbps
    Video
    Menu ID : 258 (0x102)
    Format : MPEG Video
    Format version : Version 2
    Format profile : Main@Main
    Format settings, BVOP : Yes
    Format settings, Matrix : Default
    Format settings, GOP : M=3, N=12
    Codec ID : 2
    Duration : 1h 7mn
    Bit rate mode : Variable
    Bit rate : 4 934 Kbps
    Nominal bit rate : 15.0 Mbps
    Width : 720 pixels
    Height : 576 pixels
    Display aspect ratio : 16:9
    ActiveFormatDescription : Letterbox 16:9 image
    Frame rate : 25.000 fps
    Standard : PAL
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Interlaced
    Scan order : Top Field First
    Bits/(Pixel*Frame) : 0.476
    Stream size : 2.34 GiB (78%)
    Audio #1
    Format : AC-3
    Format/Info : Audio Coding 3
    Codec ID : 6
    Duration : 1h 7mn
    Bit rate mode : Constant
    Bit rate : 448 Kbps
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Bit depth : 16 bits
    Video delay : -413ms
    Stream size : 218 MiB (7%)
    Language : English
    Audio #2
    Format : MPEG Audio
    Format version : Version 1
    Format profile : Layer 2
    Codec ID : 3
    Duration : 1h 7mn
    Bit rate : 256 Kbps
    Video delay : -370ms
    Stream size : 124 MiB (4%)
    Language : German
    Language, more info : Clean effects
    Audio #3
    Format : MPEG Audio
    Codec ID : 3
    Duration : 1h 7mn
    Bit rate : 192 Kbps
    Video delay : -330ms
    Stream size : 93.4 MiB (3%)
    Language : German
    Audio #4
    Format : MPEG Audio
    Codec ID : 3
    Duration : 1h 7mn
    Bit rate : 192 Kbps
    Language : German
    Text #1
    ID : 144 (0x90)-150
    Format : Teletext Subtitle
    Language : German
    Text #2
    ID : 144 (0x90)-777
    Language : German
    Text #3
    ID : 144 (0x90)-888
    Language : English
    I think you're covered.
  6. Alright thanks, I'll give it a try.
  7. Doesn't seem to be working out. When I'm editing the audio gets off track from the video and it won't let me save the edited video. Any other ideas?
  8. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Load your video into MediaInfo and post the details like I did. Use the TEXT option.
  9. General
    Complete name : C:\Users\User\Desktop\Video (CX 1440x1080 MPEG2 AAC).ts
    Format : MPEG-TS
    File size : 3.55 GiB
    Duration : 30mn 29s
    Start time : UTC 2012-04-07 09:54:33
    End time : UTC 2012-04-07 10:24:58
    Overall bit rate : 16.7 Mbps
    Network name : 4XEl9-0h4
    Video #1
    Menu ID : 1056 (0x420) / 1057 (0x421) / 1058 (0x422)
    Format : MPEG Video
    Format profile : Main@High
    Format settings, Matrix : Custom
    Codec ID : 2
    Duration : 30mn 29s
    Maximum bit rate : 24.0 Mbps
    Width : 1 440 pixels
    Height : 1 080 pixels
    Frame rate : 29.970 fps
    Standard : Component
    Color space : YUV
    Bit depth : 8 bits
    Compression mode : Lossy
    Color primaries : BT.709
    Transfer characteristics : BT.709
    Matrix coefficients : BT.709
    Video #2
    Menu ID : 1440 (0x5A0)
    Format : AVC
    Format profile : Baseline@L1.2
    Format settings, CABAC : No
    Format settings, ReFrames : 2 frames
    Format settings, GOP : M=1, N=30
    Codec ID : 27
    Duration : 30mn 27s
    Nominal bit rate : 219 Kbps
    Width : 320 pixels
    Height : 180 pixels
    Frame rate mode : Variable
    Color space : YUV
    Bit depth : 8 bits
    Scan type : Progressive
    Audio #1
    Format : AAC
    Format profile : LC
    Muxing mode : ADTS
    Codec ID : 15
    Duration : 30mn 29s
    Bit rate : 192 Kbps
    Minimum bit rate : 127 Kbps
    Maximum bit rate : 270 Kbps
    Delay relative to video : -147ms
    Stream size : 41.9 MiB (1%)
    Audio #2
    Format : AAC
    Format profile : HE-AAC / LC
    Muxing mode : ADTS
    Codec ID : 15
    Duration : 30mn 29s
    Bit rate : 48.0 Kbps
    Minimum bit rate : 15.4 Kbps
    Maximum bit rate : 153 Kbps
    Sampling rate : 48.0 KHz / 24.0 KHz
    Delay relative to video : -149ms
    Stream size : 10.5 MiB (0%)
    Menu #1
    List : 273 (0x111) (MPEG Video) / 274 (0x112) (AAC) / 276 (0x114) () / 277 (0x115) () / 2064 (0x810) () / 2065 (0x811) () / 2070 (0x816) () / 2079 (0x81F) ()
    Service name : |Õ¸ÆìÓ
    Service type : digital television
    UTC 2012-04-07 08:30:00 : jaÑʽËï×ì¼óÄBh32síù׸ãó×>.3X@8No.17hDj@o!$;z V / ja:ûBgÊïÈÓÇÄʤÀ|*ºÊü / reserved for future use / / 01:25:00 /
    UTC 2012-04-07 09:55:00 : / / / / 00:30:00 /
    UTC 2012-04-07 10:25:00 : / / / / 00:15:00 /
    UTC 2012-04-07 10:40:00 : / / / / 00:05:00 /
    UTC 2012-04-07 10:45:00 : / / / / 01:00:00 /
    UTC 2012-04-07 11:45:00 : / / / / 00:15:00 /
    UTC 2012-04-08 18:00:00 : ja:ÁÓÞë;RÁãó$;zV / ja:û|ÒÇ}¸¤Î?4G[üÎ4,‰ / ŠûÞë;RýL>;Iò;}ÄüÎ4, / arts/culture (without music) / / 00:30:00
    UTC 2012-04-08 18:30:00 : jaµ¶¨}µó$;zV / ja:"&IcµóÏ@V¤4i‰ / Š"&5e=UE~Mh!‰ / Š"&|¸ßù}Ï=$9TCf / arts/culture (without music) / / 00:30:00
    UTC 2012-04-08 19:00:00 : ja:F(AvCf!A|é¹Èß÷çó!A$;zV / ja:¹ÙÆÎFf¬L@é«ËÊë!H|é¹Èß÷çó"!HVAH;K>e:GBg}Î| ¹±ùë}ÇB#ë6C*ÎE83+!½·Æ!H|é¹Èß÷çó"}ÈÏ!D!½·Æ F(AvCfËB3¯?7|²ùà}¬$;}o / user defined / / 02:54:00 /
    UTC 2012-04-08 21:54:00 : ja:1H|»ó¹$;zV / ja:¤Þ51¤Æ¤ë?M¿Á¬<+J,ò9báë1;~4VÎ2a´·J}úK;·¤H`éÎ?4 òK~¿·3hNOò@8ß=P¹6u4VýL#ý@d7JÈÏ?<+J,Ka*ÎC#?M¿ÁÎ| é¤Õ¹¿¤ë}ËGwëú / entertainment programmes for 6 to 14 / / 00:06:00 /
    UTC 2012-04-08 22:00:00 : ja:Mr.|µóÇù / jaßäÍ&¯ê¹Æë"&:#=5}ÎCmL\|Ëåù¹}ò·ãÙ¯êE]¹!F|K\?M¬:#CNëÙ*>pJs¬K~:\!@/<#þ7P:Qþª6bÎ;H¤F;þ7cJQCf9qN.9TÎ|ÄÜþ?7ËÃÝó=w;R / undefined / / 01:15:00 /
    UTC 2012-04-08 23:15:00 : ja7F2K\7;Do$;zV / ja9;3D>B@O/!_KinKi!!Kids¬|ÖëùÏùÄúTM@>@n5.65!_@uARBg2p}ý t"867IG7ýDAIGOý9b8+Bt=SI'ýAKB9b66ßÊßýIpED??<#ý EZ208xJ?ý20I_9kB@ / entertainment programmes for 6 to 14 / / 00:30:00 /
    UTC 2012-04-08 23:45:00 : ja:FNN|Ëåù¹ / ja:*ç¦0lF|ò?6êJVêʬéýµéË?7·¤|Ëåù¹}òA49qÎFNN7ON sÎ5-<T¬AmNOò¢²<h:`·ªFO±¹ëF|MKLkÎDjHV|Ëåù¹ûFNNËåù¹ü! !*㹿ù:EDBe>0;R / undefined / / 00:10:00 /
    UTC 2012-04-08 23:55:00 : ja:¹ÝëÈ! / ja:FbB<¬H~·*GFqEY&EDCfM}7C"&G5\T"vs:e?@$; }o / movie/drama / / 00:30:00 /
    UTC 2012-04-09 00:25:00 : jaÙÓ¹Þ<µóÑé> / ja:ªBf>lË¢ëû|ÙÓ¹Þ4k2h@=B$9)>l}üú³³ÇÏýÞÀ|Ù¤Óù}Ê |ǣ쯿ùC#}¬ý|¹Þ¹Þ}Î|³ùÊù}ËÊë³ÈòL\;X·ý|Ù¤Óù }Ê4k2hò@=B$·Æ¤ëÎǹ! / entertainment programmes for 6 to 14 / / 00:15:00 /
    UTC 2012-04-09 00:40:00 : ja;zk$9G>3h|¢Ã×ÇùÈQ!¹ÞùÈâó*ùº!!<µóÑé> / ja:LdBjÎA0Ëû2r*J}üò65¨Æ·Þ¦?7463P|¯¤ºHVAH}¬EP>l! ʾʾLdBjä|êºà7O²ùà}Ç|¢Ê¿}ÎG>ò3h@-2=!³ÎHVAHÇ|¯¤º}Î2r*J}ò40A4|Þ¹¿ù! / pre-school children's programmes / / 00:30:00 /
    UTC 2012-04-09 01:10:00 : ja*«Ê¤È!!ßÃÉÊ¤È / ja::#LkâM}M3ʯ3Z·áë60J,!Lk99«·Î=`Hwò·Æª3Z·ßË"& |*«Ê¤È}Ï6bMKèë11;~˪0z1[·!47n20F|6bMK«éGz>PÎJ|Aw:F3+!ª3Z·ßË! / user defined / / 01:00:00 /
    UTC 2012-04-09 02:10:00 : ja:ßß¿³$;zjzV / ja:MM!9Ê?&6HÎ?MC#¬è¯µìë<ALdÈEz¨ò0l5s8x3+"&Bg4Xþ6W> )5F¬è¯µìë<ALdQH,I4D9LdBjòɦ;W¦?"&47n11F|èë 7;~«é7]G=?MSP2CF#CcIW:JEP>l / user defined / / 01:00:00 /
    UTC 2012-04-09 03:10:00 : ja:Cf1{6%GO|À¤¸§¹È / ja:F|MKF|Î|á¤óìù¹}ò¿Ã×êÈ´>R2p!99ËEl5~6%GO>lþCf ;36%GO>lÎA4|ìù¹}Î7k2LäB>>lÎ|á¤óìù¹}Î7k2Lâ*ÃÁêÈ ªFO±·Æ¤Þ¹ú6%GO|Õ¡óI,8+}ǹ!! / reserved for future use / / 00:10:00 /
    UTC 2012-04-09 03:20:00 : jaJ|âÎÕ§¹¿ / jaLHNÎ|ǣι}¬<+?.ò;}ÃÆªFO±¹ë|¹°ìâÎþ?7@=IJ}þOCBjÎ |ÒÃÈ>&IJ}þ3$30>&IJòý;kD0<TÎ3'MMÒÈêÒÈêË8l꫱ëMMË> R2p·Æ9T¯?77?DLHN|Ð鍯£! / discussion/interview/debate / / 00:25:00 /
    UTC 2012-04-09 03:45:00 : jaJ|âÎÕ§¹¿ / jaLHNÎ|ǣι}¬<+?.ò;}ÃÆªFO±¹ë|¹°ìâÎþ?7@=IJ}þOCBjÎ |ÒÃÈ>&IJ}þ3$30>&IJòý;kD0<TÎ3'MMÒÈêÒÈêË8l꫱ëMMË> R2p·Æ9T¯?77?DLHN|Ð鍯£! / discussion/interview/debate / / 00:10:00 /
    UTC 2012-04-09 03:55:00 : ja:SOUND!!WEATHER / jaá¸ãùý¤óÇ£ùº}òLdïºýNI<AÊ|ÝÃ×ßåù¸Ã¯}Î|×íâù·çóÓǪ }ËλÆýMbF|ΪE75$òªFO±¹ë2;3Z|×í°éàú / user defined / / 00:05:00 /
    UTC 2012-04-09 04:00:00 : ja:á¶Ëå!A / ja:"&>pJsK~:\ÎNEWSò>\·¯EA¨Þ¹‰ / Š"&K-IYÊENTERTAINMENT>pJs‰ / Š"&>\·¯Æ3Z·¤WEATHERM=Js‰ / Š"&A0F|ÎSPORTS¿Ã×ê8+»Þ¹ / news/current affairs / / 00:25:00
    UTC 2012-04-09 04:25:00 : ja:á¶Ëå!A / ja:"&>pJsK~:\ÎNEWSò>\·¯EA¨Þ¹‰ / Š"&K-IYÊENTERTAINMENT>pJs‰ / Š"&>\·¯Æ3Z·¤WEATHERM=Js‰ / Š"&A0F|ÎSPORTS¿Ã×ê8+»Þ¹ / news/current affairs / / 01:00:00
    UTC 2012-04-09 05:25:00 : ja:á¶Þ·|ÆìÓ / ja:"&|Ëåù¹}ÇJ*CNêË"&|¨ó¿á}Ç?4¬Lvë"&|ÈìóÉ}Ç| ï¯ï¯"&³³D4}ÇOCBjÎCf?4Ë"&|ÒÈD4}Ç?M@8Ë46F0"&|¢×ê }Ç|ÆìÓ}Ë;22C"&|*ú&}ïó³ÇL~ä·ÎD+ / news/current affairs / / 02:35:00 /
    UTC 2012-04-11 09:55:00 : jaÎó¹ÈÃ×! / ja:MCþ|ÐÊÊÞó@_3ZE}!_;3$;u@$9M<5.¢Ê¦óµù}Î?7 |³óÓúªê¸Êë}ÊL\@~Ç@Zê<hÿû:#ý|ËÃÝó}Ç5/*Ƥë|ÛóÈ}γÈüò<!!9Ë<hê>e²Þ¹ú / news/current affairs / / 01:35:00 /
    UTC 2012-04-11 11:30:00 : ja:FNN|¹Ôù¯$;zV / ja:;v7oþ;v8NÎ:G?7>pJsÏâÁíóýLkËF0¤¿@/<#ËĤÆâB?3QE*ËEA¨Þ¹ú=w@-äJl?FÎ;kE@ËN)ÿ7P:Q|Ëåù¹}âJ,«ê乯!Dû|Ëåù¹}ÏCkF 0¯ü / undefined / / 00:30:00 /
    UTC 2012-04-11 12:00:00 : / / / / 01:00:00 /
    UTC 2012-04-11 13:00:00 : / / / / 00:30:00 /
    UTC 2012-04-11 13:30:00 : / / / / 00:30:00 /
    UTC 2012-04-11 14:00:00 : / / / / 01:52:00 /
    UTC 2012-04-11 15:52:00 : / / / / 00:58:00 /
    UTC 2012-04-11 16:50:00 : / / / / 01:04:00 /
    UTC 2012-04-11 17:54:00 : / / / / 01:06:00 /
    UTC 2012-04-11 19:00:00 : / / / / 01:54:00 /
    UTC 2012-04-11 20:54:00 : / / / / 00:06:00 /
    UTC 2012-04-11 21:00:00 : ja;zk|Ô«ë}Î$9DjM}=i2s2;~4VSP$;zV / ja:OCBjÎGz>P|³óÈ}ò0zõ²47n«éû?eMK10;~üOHØ>:3 J·¿!X|Ô«ë}ÎDjM}!Yú@>FbÞêäý2C2lH~|»¤éý@iD;}Î?7 |áóÐù}¬2CïêýHVAHϵéË|Ñïù¢Ã×! / entertainment programmes for 10 to 16 / / 02:03:00 /
    UTC 2012-04-11 23:03:00 : jaÙ¤ÓùStyle$;zV / jaÙ¤ÓùStyle!D}½ìÏý@VÁãó¬2Cïÿ³ÈÇ?7¿Ë@8ÞìJQïÿ|é¤ Õ¹¿¤ë}γÈú@VÁãóòCf?4Ë2sê;Oá¿@83hÎAGE(Ê=V4Vò´>R2p· Ƥ*Þ¹ú / reserved for future use / / 00:06:00 /
    UTC 2012-04-11 23:09:00 : ja:ªÕ¯íýâ¦0lGU$;zV / ja:ûâ¦0lGU!üÈ;Wïº8@ÃÆ·Þ¦è¦Ê|«Äªþ:+I[}þ¤ê³ÊÉÎ=P=A(À·)¬8z¤¿F|K\A49qγÀïêNAM}ò>R2p·Þ¹ / reserved for future use / / 00:06:00 /
    UTC 2012-04-11 23:15:00 : ja:10J,BOX$;zV / ja:100K|1_ÎBg6bòL\ÎA0Ë·Æý?MÏ|×é¤É}ò4S±ëΫ!?K\ 2;È7zA0¬8r:9¹ë??<BÎH"û10J,BOXüú;YG[?MËÏ>>2,>;9(¬EP>l! / entertainment programmes for 6 to 14 / / 00:40:00 /
    UTC 2012-04-11 23:55:00 : ja:LIVE2012!!|Ëåù¹JAPAN&}¹ÝëÈ!$;zV / ja:=)85|*㹿ù}¬@$ÎCfÎF0*ò|*ãÃÁ!2r@b0Q0w}ÈÈâË 8!>Z‰ / Š"&|¹ÝùÄ}ò0&¹ë5.J}Ø!DKhF|¬@8J|Aw!|ÆìÓ}À«é³½E A¨ë³È¬Ç*ë|¹ÝùÄ}ÎL%NOò´Ds6!! / movie/drama / / 01:05:00
    UTC 2012-04-12 01:00:00 : / / / / 00:10:00 /
    UTC 2012-04-12 01:10:00 : / / / / 00:25:00 /
    UTC 2012-04-12 02:05:00 : / / / / 00:30:00 /
    UTC 2012-04-12 02:35:00 : / / / / 01:00:00 /
    UTC 2012-04-12 11:30:00 : / / / / 00:30:00 /
    UTC 2012-04-12 12:00:00 : ja:>PÃÆ¤¤Èâ! / ja¿âêþ>PJ!DbDaIS}þ|ÙÃ*ùþ;3:j90Li}þ|Ôù¹þ;0EDM'M|2 B¢Ê¦óµù / entertainment programmes for 10 to 16 / / 01:00:00 /
    UTC 2012-04-12 13:00:00 : ja餪ó}δ*²óè¦$;zVz[ / ja9;3D>B@O/|¹Æù¸}Ç6=J3·¹®$;}n$90aAuÎ?,äÖìÆâ|ÐéùÉ}·ÃÈê "&|ÇÓåù10G/H~;32CNx}¬4FFDËE\éì!D=wM%:2"&0f>eOB9a|ÛÆë}Ç2x8= >]$;}o|É¢}¬$93+«Ê¤ / entertainment programmes for 6 to 14 / / 00:30:00 /
    UTC 2012-04-12 13:30:00 : ja:<7?MÎE(¬¤ë!!A|ÞÞ}¿ÁÎPTAJ3F.5-!A!!#09$;zVzX / ja:5WH~(>.NS0=;R)Ø7y¬é»ò¹ëÞÉ«(M-?9Li<B)ËM[;R(??6WÄе)¬@k@oI[9p!ÞɫΪCc2qÈF1;~9oËJLΪCc2qò3+¯³ÈËúM[;RËÏ?Mò8FÖ¢ëHk:v¬!Dú / show/game show / / 00:30:00 /
    UTC 2012-04-12 14:00:00 : ja:CN꿬ê!$;zV / ja::G?7>pJsòɳèêâAa¯!"&|Ëåù¹}Î!H½â½â"2r@b"&; kD0<TÎ|®âó}ò2r7h!"&|ÆìÓ}Þ¡µ°êþþþHVAH8&5f"&0K F#Mx?Rþ=;5HH~5*þEDB<=_ / news/current affairs / / 01:52:00 /
    UTC 2012-04-12 15:52:00 : / / / / 00:58:00 /
    UTC 2012-04-12 16:50:00 : / / / / 01:04:00 /
    UTC 2012-04-12 17:54:00 : / / / / 01:06:00 /
    UTC 2012-04-12 19:00:00 : / / / / 00:57:00 /
    UTC 2012-04-12 19:57:00 : / / / / 00:57:00 /
    UTC 2012-04-12 20:54:00 : / / / / 00:06:00 /
    UTC 2012-04-12 21:00:00 : / / / / 00:54:00 /
    UTC 2012-04-12 21:54:00 : / / / / 00:06:00 /
    UTC 2012-04-12 22:00:00 : / / / / 01:09:00 /
    UTC 2012-04-12 23:09:00 : / / / / 00:06:00 /
    UTC 2012-04-12 23:15:00 : / / / / 00:40:00 /
    UTC 2012-04-13 01:00:00 : jaß¿ÑóÖù / ja:THE!!MANZAI2&<T|Ñó¯ÖùÖù}È;0ED|¢Ê}ÎW4'H VAH"&2,ED>-@8Ë50Î<ALd2?1Ä>!ëȳíÎL5¤|ÑóÖù:4F#}¬|ÉéÞ=P1i }ò7|±Æ|й±BP7h}òD)à / entertainment programmes for 6 to 14 / / 00:10:00 /
    UTC 2012-04-13 01:10:00 : ja;zk$9:dF;Î|¢Ýíó<Τ¿ßÊ>!!#01$;zV / ja:IcÈJLìÒÈê6e=#Î9b9;ØE>F~·¿70ú47ìʤ4D6-È<~0O«éÎ9%4qÎ;k@~ËBQ¨éìºý20>eØ8~«Ã¿H`òBTÁ<u±Æ¤¿ÎÏ@ n^<@iB@O:ÈÎ=P2q¤Àÿú / arts/culture (without music) / / 00:30:00 /
    UTC 2012-04-13 01:40:00 : ja;zkÄê$95e<|Τ¿ßÊ>!!#01$;zV / ja:IqBfÏ>EFnþ9>ÎEgú@D=Uò³¸é»¿4?M¬=P2q¤ýD`êò·Æý>. µÊEgÏýBg*ÊJ*8lÎCf?4ÈÊê!=!=ú‰ / г³«é;OÞëýSF(@D=U|գ÷ó°)J*8l! / arts/culture (without music) / / 00:30:00
    UTC 2012-04-13 02:10:00 : ja;zk|Õ¸ÆìÓ}«éÎ! / ja45!0lE>|êËåù¢ë!¶*äÞ}¬|Õ¸ÆìÓ}Î:G?7|³óÆóÄ}ò3 XÓʬé;kD0<T˪FO±"'|«óËó°C];3&Ïê»ó=U:Z&2,K\Nh&EOJU¢Ê&J?0f¢Ê / user defined / / 01:30:00 /
    UTC 2012-04-13 11:30:00 : / / / / 00:30:00 /
    UTC 2012-04-13 12:00:00 : / / / / 01:00:00 /
    UTC 2012-04-13 13:00:00 : / / / / 00:30:00 /
    UTC 2012-04-13 13:30:00 : / / / / 00:30:00 /
    UTC 2012-04-13 14:00:00 : / / / / 01:52:00 /
    UTC 2012-04-13 19:00:00 : ja;zk$91|Î?<F;!AF1N`¯óÎN9!ASP(2>)$;zV / ja: / cartoons/puppets / / 01:54:00 /
    UTC 2012-04-13 20:54:00 : ja:FNN|ì¤óÜùH/}þ¢¹ÎE75$$;zV / ja:³Î;~4VBSÇ5/*¿:G?7|Ëåù¹}òC;¤;~4VÎCfÇý:#EA¨Ê±ìÐÊéʤ>pJsò|³óÑ ¯È}Ëýï«ê乯CzG+˪EA¨·Þ¹ / undefined / / 00:06:00 /
    UTC 2012-04-14 09:55:00 : jaïóÔù¹!!¹Ú·ãë¨Ç£·çó$;zV / ja:ÒÈÄÊ®ÎBgHkJuòL\;X·Æ|ëÕ£}È0l«éKA81ò·Þ»ó«?|·ã ó¯¹}ÈÎ1?L?E*Ê=P2q¤ý|Êßþ¾íþ¦½Ã×þµó¸þCg4V}ÈÎ=P2q ¤ò9b2h<AÇJ|Aw! / arts/culture (without music) / / 00:30:00 /
    UTC 2012-04-14 10:25:00 : ja:@8ED¯óý|Ϥ!$;zV / ja:¤Þ:GâCmL\¹Ù*|Õ¸ÆìÓ}ÎHVAHä|¤ÙóÈ}«éý³ÎHVAHÀ±Î |¯¤º}ò=PBj!?M5$5^>e>:CfÎHi-HiÛ«<c<jª>P¤7]?M¿Á¬EZMKÎCkò@9ê>e²Þ¹! / entertainment programmes for 6 to 14 / / 00:15:00 /
    UTC 2012-04-14 10:40:00 : jaÚÃÈI42J$;zV / ja:û|ͳ}¿ÁÎ;m(¦¿)ü|ͳ}¿Á¬ý8=:_Î9,»Ê@83hË¿ÉêÄ ¯ÞÇòIA¯ú<+J,¿ÁÎ?t4qÊNr;Kò|ͳ<+?H}¬8lëý|âÎíù°7A< 0}Ç9=@.ú / tourism/travel / / 00:05:00 /
    UTC 2012-04-14 10:45:00 : jaÁãóÍë&2}þÛ³!_¿Æ$;zjzV / ja:F|4ZBP7h@dBP3+±éìʤF|K\Î6b8KVS4Z9q:G6/|«®3+}±?&?M"&@dBPIT2DG=855p?M73Ej<j|¢ì=$M} / entertainment programmes for 6 to 14 / / 01:00:00 /
    UTC 2012-04-14 11:45:00 : ja:FNN|¹Ôù¯$;zV / ja:;v7oþ;v8NÎ:G?7>pJsÏâÁíóýLkËF0¤¿@/<#ËĤÆâB?3QE*ËEA¨Þ¹ú=w@-äJl?FÎ;kE@ËN)ÿ7P:Q|Ëåù¹}âJ,«ê乯!Dû|Ëåù¹}ÏCkF 0¯ü / undefined / / 00:15:00 /
    Menu #2
    Menu ID : 1057 (0x421)
    UTC 2012-04-07 09:55:00 : jaïóÔù¹!!¹Ú·ãë¨Ç£·çó$;zV / ja:ÒÈÄÊ®ÎBgHkJuòL\;X·Æ|ëÕ£}È0l«éKA81ò·Þ»ó«?|·ã ó¯¹}ÈÎ1?L?E*Ê=P2q¤ý|Êßþ¾íþ¦½Ã×þµó¸þCg4V}ÈÎ=P2q ¤ò9b2h<AÇJ|Aw! / arts/culture (without music) / / 00:30:00 /
    UTC 2012-04-08 18:00:00 : / / / / 00:30:00 /
    UTC 2012-04-08 18:30:00 : / / / / 00:30:00 /
    UTC 2012-04-08 19:00:00 : / / / / 02:54:00 /
    UTC 2012-04-14 15:30:00 : / / / / 02:00:00 /
    UTC 2012-04-14 17:30:00 : / / / / 00:30:00 /
    UTC 2012-04-14 21:00:00 : / / / / 02:10:00 /
    UTC 2012-04-14 23:10:00 : / / / / 00:45:00 /
    UTC 2012-04-14 23:55:00 : / / / / 00:05:00 /
    Menu #3
    Menu ID : 1058 (0x422)
    UTC 2012-04-07 10:25:00 : ja;zk$9@8ED¯óý|Ϥ!$;zV / ja:¤Þ:GâCmL\¹Ù*|Õ¸ÆìÓ}ÎHVAHä|¤ÙóÈ}«éý³ÎHVAHÀ±Î |¯¤º}ò=PBj!?M5$5^>e>:CfÎHi-HiÛ«<c<jª>P¤7]?M¿Á¬EZMKÎCkò@9ê>e²Þ¹! / entertainment programmes for 6 to 14 / / 00:15:00 /
    UTC 2012-04-07 12:00:00 : / / / / 00:30:00 /
    UTC 2012-04-07 12:30:00 : / / / / 01:00:00 /
    UTC 2012-04-07 13:30:00 : / / / / 02:00:00 /
    UTC 2012-04-07 15:30:00 : / / / / 02:00:00 /
    UTC 2012-04-07 17:30:00 : / / / / 00:30:00 /
    UTC 2012-04-07 18:00:00 : / / / / 00:30:00 /
    UTC 2012-04-07 18:30:00 : / / / / 00:30:00 /
    UTC 2012-04-07 19:00:00 : / / / / 01:54:00 /
    UTC 2012-04-07 20:54:00 : / / / / 00:06:00 /
    UTC 2012-04-07 21:00:00 : / / / / 02:10:00 /
    UTC 2012-04-07 23:10:00 : / / / / 00:45:00 /
    UTC 2012-04-07 23:55:00 : / / / / 00:05:00 /
    UTC 2012-04-08 00:00:00 : / / / / 01:05:00 /
    UTC 2012-04-08 01:05:00 : / / / / 00:30:00 /
    UTC 2012-04-08 01:35:00 : / / / / 01:00:00 /
    UTC 2012-04-08 02:35:00 : / / / / 01:30:00 /
    UTC 2012-04-08 04:05:00 : / / / / 00:30:00 /
    UTC 2012-04-08 04:35:00 : / / / / 00:05:00 /
    UTC 2012-04-08 04:40:00 : / / / / 00:30:00 /
    UTC 2012-04-08 05:10:00 : / / / / 00:30:00 /
    UTC 2012-04-08 05:40:00 : / / / / 00:05:00 /
    UTC 2012-04-08 05:45:00 : / / / / 00:15:00 /
    UTC 2012-04-08 06:00:00 : / / / / 00:15:00 /
    UTC 2012-04-08 06:15:00 : / / / / 00:15:00 /
    UTC 2012-04-08 06:30:00 : / / / / 00:30:00 /
    UTC 2012-04-08 07:00:00 : / / / / 00:30:00 /
    UTC 2012-04-08 07:30:00 : / / / / 01:25:00 /
    UTC 2012-04-08 08:55:00 : / / / / 00:05:00 /
    UTC 2012-04-08 09:00:00 : / / / / 00:30:00 /
    UTC 2012-04-08 09:30:00 : / / / / 00:30:00 /
    UTC 2012-04-08 10:00:00 : / / / / 01:45:00 /
    UTC 2012-04-08 11:45:00 : / / / / 00:05:00 /
    UTC 2012-04-08 11:50:00 : / / / / 00:10:00 /
    UTC 2012-04-08 12:00:00 : / / / / 01:00:00 /
    UTC 2012-04-08 13:00:00 : / / / / 01:00:00 /
    UTC 2012-04-08 14:00:00 : / / / / 00:55:00 /
    UTC 2012-04-08 14:55:00 : / / / / 00:05:00 /
    UTC 2012-04-08 15:00:00 : / / / / 01:00:00 /
    UTC 2012-04-08 16:00:00 : / / / / 01:25:00 /
    UTC 2012-04-08 17:25:00 : / / / / 00:05:00 /
    UTC 2012-04-08 17:30:00 : / / / / 00:30:00 /
    UTC 2012-04-08 21:54:00 : / / / / 00:06:00 /
    UTC 2012-04-08 22:00:00 : / / / / 01:15:00 /
    UTC 2012-04-08 23:15:00 : / / / / 00:30:00 /
    UTC 2012-04-08 23:45:00 : / / / / 00:10:00 /
    UTC 2012-04-08 23:55:00 : / / / / 00:30:00 /
    UTC 2012-04-09 00:25:00 : / / / / 00:15:00 /
    UTC 2012-04-09 00:40:00 : / / / / 00:30:00 /
    UTC 2012-04-09 01:10:00 : / / / / 01:00:00 /
    UTC 2012-04-09 02:10:00 : / / / / 01:00:00 /
    UTC 2012-04-09 03:10:00 : / / / / 00:10:00 /
    UTC 2012-04-09 03:20:00 : / / / / 00:25:00 /
    UTC 2012-04-09 03:45:00 : / / / / 00:10:00 /
    UTC 2012-04-09 03:55:00 : / / / / 00:05:00 /
    UTC 2012-04-09 04:00:00 : / / / / 00:25:00 /
    UTC 2012-04-09 04:25:00 : / / / / 01:00:00 /
    UTC 2012-04-09 05:25:00 : / / / / 02:35:00 /
    UTC 2012-04-09 08:00:00 : / / / / 01:55:00 /
    UTC 2012-04-14 18:00:00 : / / / / 00:30:00 /
    UTC 2012-04-14 18:30:00 : / / / / 00:30:00 /
    UTC 2012-04-14 19:00:00 : / / / / 00:57:00 /
    UTC 2012-04-14 19:57:00 : / / / / 00:57:00 /
    UTC 2012-04-14 20:54:00 : / / / / 00:06:00 /
    Menu #4
    List : 337 (0x151) (AVC) / 338 (0x152) (AAC) / 340 (0x154) () / 2128 (0x850) () / 2129 (0x851) ()
    Service type : user defined
    That was everything it said.
  10. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    So this came from a set-top DVR?
  11. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    I run my DVR recordings through ProjectX first. It fixes all of the sync issues related to these files. There is no guarantee is till work with your files but it is fantastic with the files my box creates.
    It's a JAVA based program.....it doesn't START like a normal program.
  12. Yeah that didn't work. Any other ideas?
  13. By the way. I tried to edit it after converting it to an mkv, but it was the same issue.
  14. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    How did you start ProjectX ?
    Did you demux or just straight to a new TS?
  15. I couldn't install it. Also I don't know if this has anything to do with it, but When I loaded it into Avidemux it said that there were two audio files.
  16. I think I have it figured out. I believe that I need to create a vbr time map so that the audio and video will be in sync. I think it has something to do with it not being at a constant bit rate. The only problem now is that it doesn't seem to work. I think I need to get mad (mpeg audio decoder: http://www.underbit.com/products/mad) or something. The only thing is I don't know which one to get or how it works.
  17. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    You didn't even try.
  18. I tried, But I don't know how to point it to my java home
  19. I just found out that MAD doesn't support AAC audio. So I will need something else to sync the files, I wam willing to try the Project_X program, but I don't know how to point it to my Java home.
  20. Alright, I figured out how to get the program working, I demuxed the file and it split it into two files, an m2v and an mp2. When I loaded them into avidemux it crashed. I am going to attach the very long log project_x gave me. It had a lot of errors and ignored many things as you will see.
    Jan 2011
    Adelaide, Australia
    Try Video ReDo. It's not free but it hasn't failed me yet when editing .ts files.
  22. I am not willing to pay for this kind of thing though. Isn't there any program that will let me edit a .TS file with MPEG-2 and AAC codecs? All I need to do is cut parts away from it.
  23. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Prepare - To TS checkbox.
    Of course all of this could be a waste of time. I get the feeling this is not from your set top box and you have no idea if these are copy protected or at least "scrambled" in some way.
  24. Then you have the wrong idea. I will try preparing it to a TS
  25. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    You do realize that a set-top box/recorder that DOESN'T copy protect or adhere to the copy protection sent out by TV stations(like mine) is the RARE one....don't you?
  26. Yes, I do, I am positive it isn't protected. When I set it to prepare a TS it split the audio into four tracks, instead of the two it was originally in and none of them have the proper audio. What if I converted the audio to a different codec using handbrake and then tried to edit it. If you think that will work then let me know what codec to change it to.
