Poll: Should I convert dv to svcd/x(s)vcd OR divx5?
Be advised that this is a public poll: other users can see the choice(s) you selected.
    Jan 2002
    I want to backup my minidv tapes (to free them up).
    I'm wanting the highest quality video and audio possible (heh, doesn't everyone).
    My question is . . .
    . . . should I convert it to svcd or x(s)vcd
    OR
    convert it to divx using divx 5?
    Thanks for your opinions!
  2. If you want a backup, I'd compress the avi's and back them up to data cd-rs.
    If you want to watch your backups on your TV i don't think divx 5 is gonna work (could be wrong with all the new players out there)
    If ya have say a 50 inch plasma display hooked up to your PC i'd
    say life's treatin ya well!
    I've authored some home movies from miniDV and you almost have
    to go with XSVCD because the source tends to have too much jumpy
    movement and wild ass panning.
    OBTW: at $5 - $8 a 60 min tape, miniDV is not a bad backup option if
    you factor in your time.....
    I mean it in the nicest way.
