Results 1 to 12 of 12
  1. hello wonder if anyone could help me
    i have a LG mw237 wd never used the hdmi ports as i connect my 360 via component
    recently bought a sony home theatre but hdmi never seemed to work so sent it back thinking it was the system
    Got a Lg bh4120s and it works fine via s video
    but when connecting to hdmi it only shows the box in the right hand corner displaying 480p 60hz
    the only time i will get a image is when i first start up the BD player and it literally flashes up for 2 secs and then disappears
    i can hear audio just no video please help
    thank you
  2. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    What's the question?
  3. darn sorry
    my issue is that it doesnt seem to connect via hdmi , i have to use the yellow video lead to see the screen then only i can flick over to the hdmi input but the screen is blank although i can hear sound
    i press the ok i can see it displays 1080p 60hz
    only way i see a image is if i turn off blu ray and power up i see the lg logo then it goes blank>>>
    ive tried with another LG tv same issue tried with a ikasu tv and worked staight away
    my xbox connects to tv via hdmi with no issues.?
    would like to know what tyhe problem is was so looking forward finally watching BD and it dont work lol
    iv also tried various hdmi cable
  4. Banned
    Freedonia
    You may have to see if there is some way to reset the player to factory specs. Outputting 1080p 60Hz seems really odd for someone in the UK so it may be that the player is not set up correctly. It may be that your LG TV does not accept this for video input. If you connect it to your LG TV via something other than HDMI you may be able to go into the setup menu and change the output. I can't find any info on your TV based on the model you gave, but assuming you really bought it in Europe I would think that 1080p 50Hz output is what you want on the BluRay player.
  5. Originally Posted by jman98 View Post
    thanks for the quick response iv reset the settings on the monitor with no avail
    i bought the monitor of ebuyer about 09/10
    i accesed the Blu ray menu by using the yellow video cable was able to change to auto detect but when i change to hdmi channel blank screen but still has the 1080p 50hz in the box
    im confused because if im on the hdmi channel and start up the player i can see the LG welcome screen but as it switching to the menu it goes blank and i have to go back to the video channel to access menu>>>
    ty
  6. I'm a Super Moderator johns0's Avatar
    canada
    cboyuk-please do not post in other threads when you have one already started,i deleted your posts in that thread.
  7. Anonymous19484
    Guest
    Are you using the right hdmi cable? there are different versions of hdmi and i have seen this type of problem before due to a lower hdmi version cable.
    You need at least hdmi version 1.3a or higher for 1080P output ( if i'm not misstaken)
    If you have a 3D player you need a version 1.4 cable
  8. Originally Posted by johns0 View Post
    ok im sorry
    Aug 2006
    Google can't find any relevant links but this thread when I search for " LG mw237". LG's UK website doesn't list it either. Are you certain that model number is correct?
  10. Originally Posted by usually_quiet View Post
    yes im sure its flatron mw237 wd
    Aug 2006
    Searching for "LG mw237 wd" turned up nothing but your thread here at Video Help and nothing at LG's UK website again.
    However searching for "LG m237wd" found a 23-inch LCD computer monitor/TV.
    If that is what you have, check to see if your BD player is configured to send 480i or 576i over HDMI. If so, your monitor won't display it. According to the manual, it will only display 480p, 576p, 720p, 1080i, and 1080p signals when using HDMI.
  12. Originally Posted by usually_quiet View Post
    thanks my BD supports upto 1080p and so does monitor .. i think ill have to invest into a new tv thanks for the help
