    Oct 2008
    Hello
    I've been using 1Click DVD Movie software to convert video files to DVD.
    I have been trying to convert VOB to DVD, when i try and convert, i get a box pop up stating. VOB files are not supported - please choose another file type.
    Is there a codec or something i can install that will allow me to convert VOB to DVD using 1Click DVD Movie software?
    Do you just have a vob file?
    Or a complete VIDEO_TS folder with vob,ifo,bup files?
    Oct 2008
    Thanks for reply.
    I have two discs, one disc with one TV programme on and five TV programmes on the other disc. I extracted contents from each disc to two separate folders.
    I have taken video files from each folder and changed the numbers. Each file is a TV progamme.
  4. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    [Attachment 13216 - Click to enlarge]
    I doubt that. They are all the same exact size.
  5. I'm a MEGA Super Moderator Baldrick's Avatar
    Try reauthor with dvd flick. Add all vobs. Under the settings select to not reconvert dvd compliant streams.
