I downloaded an anime movie and it seems to be split into 2 OGM video files, so I want to merge the files into one video file (preferably without a quality loss)
I tried using a few programs, but none work (various reasons: OGM format isn't supported/ corrupt output/ watermark...)
Both files are 640x480, both have dual audio, first part is 45:04 minutes long, second part is 34:39 minutes long, and their size is 700MB each (together it's 1.4GB).
Maybe try reconvert just the audio part, under audio choose vorbis or mp3(lame). And see how it work.
Same results. (I used Vorbis)
Edit: I finally got it to work, this is what I did -
Opened part one with avidemux, reconverted with the Vorbis option under audio
Did the same with part two
Then merged them (again with the Vorbis thing) and it worked
Thank you for your help.Last edited by Anonymous11; 26th Jul 2012 at 07:08.
Need to batch-convert videos to MP4 using same bitrate as source videos
By BLboy in forum Video ConversionReplies: 8Last Post: 10th Jan 2026, 15:42 -
avisynth..merging videos...
By prat_at_bits in forum Newbie / General discussionsReplies: 1Last Post: 12th Nov 2010, 09:16 -
mkvmerge is not splitting videos to dvd5 size+ rotating videos+resizing
By rocketman122 in forum EditingReplies: 2Last Post: 24th Aug 2010, 09:12 -
Merging two videos of wedding. Need direction.
By Montezuma45 in forum EditingReplies: 11Last Post: 22nd Jun 2009, 19:56 -
Conversion usiing VirtualDub - 720 X 560 videos into 640 X 360 videos
By candyman9999 in forum Video ConversionReplies: 1Last Post: 13th Jan 2009, 23:13
