Hi,
I have configured Darwin streaming server, and trying to stream quicktime / mov videos converted using FFMPEG, but they don't seem to be streaming. Streaming server gives "Unsupported Media Type" error.
I tried with all available video codecs for quicktime -
mpeg4
libx264
svq1
mjpeg
but the problem persisted with all of them.
Does FFMPEG not have capability of generating streamable quicktime renditions ??
thanks,
Rajiv
It's not mainly in the codec, it's mainly in the container. This has to do with 1) the index of timecodes being put in an atom at the beginning of the file, 2) the presence (or absence) of a hinting track, 3) the presence (or absence) of other Quicktime-specific flags/atoms that signal to Darwin server that it is proper to stream with, and to a much lesser extent, 4) the interleave of V+A+H+TC in proper packetized sizes to make it easier to stream.
You've got to remember, the QT capability in ffmpeg is likely reverse-engineered from the MP4 spec and work with Hex Editors+AtomViewer, so it may not get everything correct.
My hunch is that NO, ffmpeg does NOT generate valid streamable QT renditions.
Though you might be able to remux them into correct format using QT Pro.
Cannot encode .mov file to dvd using ffmpeg
By RL in forum ffmpegX general discussionReplies: 3Last Post: 25th Oct 2011, 14:43 -
Is there a way to normalize a .mov file in Quicktime ?
By abrand88 in forum Newbie / General discussionsReplies: 1Last Post: 23rd Apr 2010, 12:03 -
I can't edit this mov quicktime file
By qisheng in forum EditingReplies: 19Last Post: 1st Dec 2009, 03:05 -
Converting (Quicktime) .MOV file to .WMV file
By stanislawski in forum Video ConversionReplies: 2Last Post: 6th Feb 2008, 18:19 -
how to make ffmpeg recognize an uncompressed quicktime source file?
By eighth in forum ffmpegX general discussionReplies: 0Last Post: 21st Dec 2007, 14:09
