hello
i have downloaded arabic subtitles for a divx movie and after installing them the timing was not correct does anyone know how to make the timing right please??![]()
Results 1 to 9 of 9
If it's a text based format like subrip (.srt) you can do this in many different programs, e.g.:
- SubtitleEdit - http://www.nikse.dk/SubtitleEdit/Help#sync
- SubtitleWorkshop
- Aegisub
And many other programs too!
Another solution would be finding a sub with correct time codes. -
i can change srt files into txt files but can you change them back to srt files??
i use subtitles with srt format and i read that you can change them to txt files to correct language then change them back but i don't know how to change them back!
the subtitles in the movie appear in charachters but in the programs you gave to me they seem correct
An srt file IS a text file. It looks like this:
You can read up about it here: http://en.wikipedia.org/wiki/SubRipCode:1 00:00:20,000 --> 00:00:24,400 Altocumulus clouds occur between six thousand 2 00:00:24,600 --> 00:00:27,800 and twenty thousand feet above ground level.
So if you want to translate it into some other language, say Arabic, you can put the .srt directly into a text editor (or subtitle editor) and replace with the correct text. Obviously, with Arabic or similar languages, you'll want to use different character codes (probably higher up in the Unicode set). If you already have your keyboard set up for this, you should be able to type directly, otherwise you can always type in the code # combination. Or paste from Character Map. For example:
ز is unicode character 0632
auto timing for subtitles any software
By userwords in forum SubtitleReplies: 0Last Post: 30th May 2010, 19:34 -
Syncing timing with additional subtitles?
By architectofpain in forum SubtitleReplies: 0Last Post: 6th Mar 2010, 02:16 -
Error in DVDSubedit when re-timing subtitles
By kpic in forum SubtitleReplies: 2Last Post: 22nd Feb 2010, 05:08 -
subtitles timing
By teamo1976 in forum SubtitleReplies: 3Last Post: 21st Dec 2009, 16:58 -
timing off on extracted subtitles?
By ecc in forum SubtitleReplies: 0Last Post: 24th Feb 2008, 07:37
