When i import a long video in Premiere Pro CS6, in time line, it's time is shorter than it's real time. ( for example a MP4 Film with 2:18:15 length changes to 2:18:6) . I want to sync an audio on film and this difference will makes error. what is the problem ?
(sorry for my english!)
Hi
It's likely to be a Framerate problem.
Check your project/Timeline properties, and be sure it's the same framerate than the footage you are using.
For instance, if you shot in 25fps, both project and timeline settings must be set on 25 frame per second. (same if it's 23.976, or 29.970, 30 fps, etc. )
The timeline settings may not be referred as "fps", but maybe as "Timecode Set" (check for SMTPE standards)
Good luck
Premiere Pro CS6 Capturing MP3 Only on HDR-HC1
By maxruddock12 in forum Capturing and VCRReplies: 25Last Post: 20th Jun 2015, 05:17 -
Laptop for Adobe Premiere Pro CS6
By Amira_S in forum Newbie / General discussionsReplies: 5Last Post: 7th Aug 2012, 11:01 -
Adobe Premiere Pro How do I make the video Bigger?
By Devilsadvocate in forum EditingReplies: 5Last Post: 25th Mar 2012, 16:44 -
Video problem in adobe premiere pro 1.5
By saifshuvo in forum EditingReplies: 1Last Post: 5th Apr 2009, 15:16 -
Replace imported footage in Premiere Pro?
By Colmino in forum EditingReplies: 3Last Post: 9th Jun 2008, 06:37
