Here is a sample video
http://www.sendspace.com/file/j0nn87
Here is encode settings and mediainfo
http://pastebin.com/heZ6LKHz
I know this has been asked a lot, but what could i change to make the video look a little better? I know it look's good for being a 1.56gb file with ac3 audio. I just seem to think i could get it to look better, i used Spline64Resize btw in case that matters.
Any pointers would be great, i'm still pretty new to all this and learning.
Here are the exact settings i'm using.
http://i48.tinypic.com/rku4r6.jpg
http://i45.tinypic.com/ilww3c.jpg
http://i45.tinypic.com/2uorxih.jpg
http://i50.tinypic.com/nq71as.jpg
Results 1 to 30 of 49
The original source is a bluray so i can't keep it the original resolution and i might sound dumb, but what are SAR flags?
--level 4.1 --preset veryslow --pass 2 --bitrate 2111 --stats ".stats" --deblock 1:1 --bframes 3 --b-pyramid strict --ref 5 --rc-lookahead 120 --merange 16 --subme 9 --psy-rd 1.0:0.02 --output "output" "input"
Is that good for SD ? I looked at it to my original and it looked brighter with more detail. -
Which was brighter and had more detail?
The command i posted with that post, by original i meant it looked better then the encode that i gave a sample of, not the bluray :P. It just looked little better to me, should i maybe try doing a 10bit encode?
10bit won't work in pretty much everything, correct? Only on pc? -
It's so hard to compare them by same frame as media player classic doesn't go to the same frame even when you type the same frame. So i really don't know how to see the exact same frame on both. I was just going by watching them side by side.
You can't compare two videos using two media players side-by-side. One may get access to the graphic's card's hardware (with different brightness, contrast, colors, filters, etc.), the other not . Try looking at the same video file in two players -- you'll see differences there too.
I usually use an AviSynth script to open each video and stack them side by side or interleave them. Then use VirtualDub to view the script.
Code:v1=WhateverSource("filename1.ext") v2=WhateverSource("filename2.ext") StackHorizontal(v1,v2)Another good script stacks the two videos side-by-side and also displays the differences between them and the differences amplified:Code:v1=WhateverSource("filename1.ext") v2=WhateverSource("filename2.ext") Interleave(v1,v2)
If you can't use AviSynth use VirtualDub to view each file directly. Be sure to disable DirectX output to make sure the program doesn't use the graphics card's hardware.Code:# If Videos start at different frames use frameadjust to align them frameadjust=0 name1="video1.avi" name2="video2.avi" v1 = AviSource(name1) v2 = AviSource(name2).trim(frameadjust,0) sub = v1.subtract(v2) substrong = sub.levels(112,1,144,0,255) StackVertical(StackHorizontal(v1.subtitle(name1),v2.subtitle(name2)),StackHorizontal(sub.subtitle("Difference"),substrong.subtitle("Difference amplified 8x")))Last edited by jagabo; 25th Jul 2012 at 11:17.
I'm not sure what you're asking. By "WhateverSource" I mean use whatever source filter is required to open your source video. AviSource, ffVideoSource, DirectshowSource, Mpeg2Source, etc.
Your sample.mkv can be opened with ffVideoSource("sample.mkv"). Use ffmpegsource from here:
http://code.google.com/p/ffmpegsource/downloads/detail?name=ffms2-r683.7z&can=2&q=
Put FFMS2.AVSI and FFMS2.DLL in your AviSynth plugins folder.Last edited by jagabo; 25th Jul 2012 at 11:57.
That allows me to open the avs now, but i get "couldn't locate decompressor for format YV12 etc etc"
and when i hit ok it does nothing so i see nothing. -
v1=ffVideoSource("C:\Users\*****\Desktop\x264test\ crf.mkv")
v2=ffVideoSource("C:\Users\*****\Desktop\x264test\ 2pass.mkv")
Is the script that he told me to try. -
Would there be a way for me to take two screen shots of both files using avspmod instead of big screenshot of both?
Never mind
http://screenshotcomparison.com/comparison/137480
It's hard to see any real difference between the two besides the fact the cfr file is smaller.Last edited by kkiller23; 25th Jul 2012 at 14:53.
use different tabs (individual scripts of each video in each, not the script you used above) you can take screenshots with avspmod (video=>save image as)
using different tabs is a good way to see the effect of filters as well, you can have different versions of scripts and filters and swap back & forth easily with the number keys -
Also, any reason why you chose exactly 2111kbps ?
And why are you resizing to SD ? -
So i could get a filesize of 1.56gb with the ac3 audio that's why i picked 2111 as a bitrate.
It's not a valid comparison when you compare different bitrate videos
If you are comparing CRF , you would have to do repeat fractional encodes (e.g. CRF 22.1, 22.2, etc...) until the bitrate was exactly the same as the 2pass video (plus all the other settings identical of course)
As this is teduous - practically speaking, it's usually done the other way around - you encode at a certain CRF value, then use that bitrate to compare a 2pass encode
This is pretty much useless because it's been done a zillion times - the established fact is that it's almost identical (not quite, the distribution is very slightly different) -
I just thought that file size was to small for HD and there wouldn't be enough bits per pixel to look good.
Also, with crf lower is better? Then i guess i won't be getting it looking much better then the original sample i uploaded?
I'll just stick with two pass encodes atleast i'll know the filesize then hahaLast edited by kkiller23; 25th Jul 2012 at 15:25.
x264 settings/AVCHD
By soneca in forum Video ConversionReplies: 6Last Post: 13th Jan 2012, 06:51 -
x264 Mediainfo to MeGUI x264 Settings
By shagratt71 in forum Video ConversionReplies: 0Last Post: 1st Jan 2012, 05:59 -
Question about x264's Tuning settings
By CubDukat in forum Video ConversionReplies: 0Last Post: 5th Dec 2011, 00:17 -
Optimum x264 encoding settings
By zammil in forum Video ConversionReplies: 27Last Post: 18th Dec 2010, 01:32 -
FfmpegX x264 settings
By bvdw in forum ffmpegX general discussionReplies: 4Last Post: 20th Jan 2009, 14:23
