I demuxed an MPEG2 with TS Muxer. When I remuxed it gives an MPEG 2 .tS file. If I want to change this to MPEG2 can I just change the file name to ".mpg" or do I actually need to remux it to MPEG2?
yes, you need to remux into mpeg2 program stream (mpeg2-ps) => this usually has .mpg or .mpeg extension
you can't just rename the extension, a program stream is different than a transport stream -
I use this program to convert *.ts files recorded by my Hauppauge capture card to *.mpg:
https://www.videohelp.com/tools/HDTVtoMPEG2
How to import MPEG2-TS to Adobe Premier? How to convert MPEG2-TS to MKV? :)
By farzad in forum EditingReplies: 19Last Post: 29th Feb 2012, 16:25 -
mpeg2 ts file convert to mkv or mpeg2 ts......change only video bitrate...
By jrblack in forum Video ConversionReplies: 4Last Post: 24th Jan 2011, 18:45 -
Merging MPEG2 stream with its AC3 audio... or converting MKV to MPEG2
By cwt in forum Video ConversionReplies: 2Last Post: 5th May 2010, 14:18 -
Simple question: how to compress 4GB mpeg2 to 1GB mpeg2
By jimdagys in forum Newbie / General discussionsReplies: 29Last Post: 3rd Jan 2008, 08:45 -
converting to mpeg2
By thecrock in forum Newbie / General discussionsReplies: 11Last Post: 12th Nov 2007, 16:08
