I bought a BLUray movie the other day and gave it to a friend to rip it for me(i don't know how to do these kind of stuff)
I use a pretty simple and cheap editing program that fulfills my needs called Vegas Movie Studio HD Platinum 11... My problem is that when I insert this file in vegas, both the preview screen and the trimmer turn completely green instead of showing the actual movie.
anyone knows what the problem is? I'll let you some info on the filebtw i already enabled H.264/AVC inn ffdshow
Thanks guys!
General
Complete name : C:\Users\Windows\Desktop\[MYBPRIP]One Piece Movie 05.mp4
Format : MPEG-4
Format profile : Base Media
Codec ID : isom
File size : 5.86 GiB
Duration : 1h 34mn
Overall bit rate : 8 846 Kbps
Video
Format : AVC
Format profile : High 10@L5.0
Format settings, CABAC : Yes
Format settings, ReFrames : 6 frames
Codec ID : avc1
Duration : 1h 34mn
Bit rate mode : Variable
Bit rate : 8 100 Kbps
Maximum bit rate : 40.0 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 10 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.163
Stream size : 5.37 GiB (92%)
Writing library : x264 core 118 r2085+614 d1cc25d
Encoding settings : cabac=1 / ref=6 / deblock=1:-3:-3 / analyse=0x3:0x133 / me=umh / subme=9 / psy=1 / fade_compensate=0.00 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=32 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=3 / sliced_threads=0 / nr=0 / decimate=0 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / fgo=0 / bframes=12 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=0 / bitrate=8100 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=81 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=40000 / vbv_bufsize=50000 / nal_hrd=vbr / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:1.00
Audio
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 1h 34mn
Bit rate : 742 Kbps
Maximum bit rate : 933 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Compression mode : Lossy
Delay relative to video : -3s 337ms
Stream size : 504 MiB (8%)
Language : Japanese
	Instead of ripping, I use the Hauppage HDPVR to record it in realtime at whatever bitrate level I want. The recording is AVC/AAC or "H.264", just like the rip, but lighter on system resources, so you can use it right away in Vegas.
 OR, you can transcode it to Mpeg2, AVI, or whatever, with Handbrake, for your other devices. And you might want to record whatever else is playing on your TV, or coming out of some internet box, ahem.
 Also, rentals are only 24hrs. Far too short a time frame. You want to get your dollar's worth, right? You want to get your dollar's worth, right?
 PDR already answered your question, but since you're in to Vegas and movies, it doesn't hurt to be prepared for the future.Last edited by budwzr; 24th Jul 2012 at 16:50.
	Hmmm i dont know a lot about these things since i wasnt the one who did them
 Don't I have any other options?
	Have a good one,
 neomaine
 NEW! VideoHelp.com F@H team 166011!
 http://fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=166011
 Folding@Home FAQ and download: http://folding.stanford.edu/
  Shrinking 1080p MKV, change to 720p or keep as 1080p?By Phat J in forum Video ConversionReplies: 5Last Post: 28th Nov 2010, 10:35
  footage from 5d Mark II mixed with XLII footageBy segan in forum Newbie / General discussionsReplies: 2Last Post: 13th May 2010, 15:24
  1080P Playback On My PC? And WD 1080p Player Need A Expert!By wpittsen in forum Newbie / General discussionsReplies: 2Last Post: 30th Sep 2009, 13:43
  HDV 1080p Im Looking for 1080p HDVs.By ChristianPaprika in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 19Last Post: 16th Nov 2008, 22:05
  Why can't I get 1080p?By L7dra7 in forum Newbie / General discussionsReplies: 3Last Post: 26th Dec 2007, 15:13
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
