  1. Member ranchhand's Avatar
    Oct 2005
    USA-midwest
    This looks like an interesting utility if dependable; it does driver backups very well but I have not restored with it yet. Could be useful in older systems where the drivers are no longer available and I want to reinstall the OS. Anyone ever restored with it?
    http://boozet.org/dd.htm
    canada
    ranchhand-in the future please use a more descriptive subject title in your posts to allow others to search for similar topics. I will change yours this time.
  3. Member Cornucopia's Avatar
    I tried it with 2 PCs- 1 that had the drivers already installed, and another (supposedly identical model & lot) that didn't. Wouldn't work. At all.
    Went back to just creating a "driver installer" cd. Worked fine (with the SAME drivers as above).
    Either the models were just enough different that the "restore" wouldn't work correctly, or the backup/restore doesn't account for everything necessary.
    Either way, I'm not using that again.
  4. Have seen several similar programs, never encountered one that was worth a damn.
    "drivers no longer available" is pretty darn rare. Haven't really run into that since DOS days, other than some truly oddball hardware. If it's that weirdo, I don't really want it in the box, anyway.
  5. Member ranchhand's Avatar
    Oct 2005
    USA-midwest
    Johnso: sorry about that, I accidentally hit the post button before I was finished typing the subject header. I couldn't find any way to edit the subject header, if there is one let me know. It was intended to read as you fixed it. To all, thanks for the replies. Cornucopia: how did you create a driver installer cd?
  6. Member Cornucopia's Avatar
    Researched the drivers needed for a particular pc configuration and downloaded them (if I didn't already have copies) .
    Then burn them to disc, organized into fumctional/hardware category folders.
    No need for autoinstalls or menus, just some info text files.
  7. Banned
    Jun 2004
    ®Inside My Avatar™© U.S.
    It's easy, first you click the "Edit" button in your first post,
    then you click the "Go Advanced" button,
    Then you can edit your title.
  8. Member ranchhand's Avatar
    Oct 2005
    USA-midwest
    Thanks Noahtuck... I made a note of it.
