This may have been asked before, but is using Windows Vista Readyboost and a speedy flash drive a good way to speed up video processing, whether it's authoring a DVD, converting, capturing, etc?
I don't believe it will help noticeably for the tasks you mention.
Readyboost can help caching (with Superfetch turned on) a little if one's computer is seriously deficient in RAM, like 512 MB. I have a netbook with 1 GB RAM and use an extra SDHC card for Readyboost. Can't say it helps for much of anything, other than loading programs a bit faster.Pull! Bang! Darn! -
If you get one that has a light on it you can see when it's accessing it. Anyway, it's only about $5 to try it. It is 4x faster than writing to a HD.
How is a USB flash drive device writing faster than direct-to-HDD?
it helps for progs like firefox (start faster)
one important thing
Microsoft recommends the amount of flash memory for ReadyBoost acceleration be one to three times the amount of random access memory (RAM) in your computer. This recommendation should not be confused with the message that is displayed in the “ReadyBoost” tab of drive properties dialog: for example, for a flash drive of 16 GB capacity formatted as FAT32 it will display a message that “Windows recommends reserving 4094 MB for optimal performance” even if RAM size is 10 GB, just because 4094 MB is the maximum file size on a FAT32 volume; after reformatting it as NTFS or exFAT, the message changes to “Windows recommends 15180 MB”.*** DIGITIZING VHS / ANALOG VIDEOS SINCE 2001**** GEAR: JVC HR-S7700MS, TOSHIBA V733EF AND MORE -
video processing - languages and libraries?
By possom in forum ProgrammingReplies: 2Last Post: 17th Jul 2012, 22:15 -
ReadyBoost, Anyone ?
By themaster1 in forum ComputerReplies: 5Last Post: 2nd Mar 2012, 06:36 -
Looking For Video Processing Problems
By Saint_Emperor in forum EditingReplies: 8Last Post: 6th May 2011, 16:25 -
CPU Utilization during video processing
By Browncoat in forum Newbie / General discussionsReplies: 4Last Post: 24th Apr 2010, 07:22 -
What are some good video processing scripts?
By rocky12 in forum Newbie / General discussionsReplies: 21Last Post: 26th Oct 2008, 23:40
