I want to convert the output of the Hauppauge HD PVR from component to composite so I can play on my Standard Def TV while recording in HD: The HD PVR's input will be HD 1080i from an xbox 360
http://www.ebay.ca/itm/120816658427?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649...ht_1213wt_1037
So I need to know if converting the output will effect the input and possibly record SD or something. Also, will the quality of the converted composite be the same as if I were playing straight from xbox 360 composite cables? Thanks, and maybe some1 has some experience with a converter like this.
What happens to the signal downstream from the HDPVR will have no effect on what the HDPVR is recording.
I don't know about the quality of the particular device you linked to. It probably won't be quite as good as the Xbox 360's composite output. -
I haven't tried any converters, so I can't tell you, but I don't see any particular reason to think they would be significantly worse than the normal output. However, I'm quite sure it won't affect the input, it will be electrically different than the PVR input so it can't affect it.
You stated you only have an SD TV, however if you have an LCD monitor, there's ways to hook that up too, and yes without any lag.
Also if you're looking for converters, see if there's one that will output svideo, that is if your TV has svideo, because it will look a little better. Just a bit though, like possibly no little colored dots at borders and less smeared colors. -
MUST....
FIGHT.....
SATANS.....
URGES.......
Exactly WTF are you smoking ?!?!?!? -
I don't think you need to stress much about the converter, unless there's something really wrong with it, the differences should hardly be noticeable. I have used a few tv modulators and video distribution amplifiers and they look fine.
Is there a converter that can match the input and output bitrates?
By aslaksen in forum Video ConversionReplies: 6Last Post: 22nd Feb 2011, 04:53 -
progressive input gives interlaced output...
By bennn in forum ffmpegX general discussionReplies: 4Last Post: 9th Dec 2010, 13:32 -
DVI PC output to HDMI HD TV input?
By eros in forum DVB / IPTVReplies: 1Last Post: 26th Sep 2010, 02:38 -
RF output to DVI/HDMI Input
By torrentkid in forum Capturing and VCRReplies: 4Last Post: 19th Jun 2010, 03:41 -
spdif output hack to input?
By tsantsa in forum ComputerReplies: 4Last Post: 31st Oct 2008, 01:59
I would not want to play on my monitor as it is too small. Thanks for helping me out.
