WinFF 1.42
setting MPEG-4, H.264 video
avi file: e.g. 250 MB
if set to (high quality)
mp4 file around 65MB
if set to (very high quality)
mp4 file around 170MB
mp4 file over 220MB
does anybody now how
to alter these settings to
end up with files around
half the original size?
Damian
Though I'm sure there are more "technical" solutions (e.g. find a better encoder), this will certainly work if you can live with a "smaller" video.
First, check the original "size" of the film (720x576 / 320x240 / 1280x720, etc.). Then go to the WinFF "Video" tab (click the "Options" button at the top right to see it in case you can't).
There you can set a smaller "Video Size". Of course you can also reduce the bitrate, frame rate, etc. too.
It all depends on how much quality you can stand losing.Lenovo ThinkStation P520, Xeon W2135; Win10Pro x64, 64Gb RAM; RadeonPro WX7100W; NEC PA301W, NEC PA272W, and Eizo MX270W.
Does FFmpeg/WinFF remux or convert?
By Thunderhead2772 in forum Video ConversionReplies: 2Last Post: 23rd Nov 2011, 18:29 -
Would like better winff h.264 mp4 preset.
By Verlager in forum LinuxReplies: 26Last Post: 16th Jul 2009, 19:24 -
WinFF / ffmpeg - Unwanted Deinterlacing
By dLee in forum Video ConversionReplies: 5Last Post: 24th Mar 2009, 17:28 -
SVN ffmpeg now supports iTunes friendly muxer: WinFF presets
By GMaq in forum LinuxReplies: 0Last Post: 26th Oct 2008, 14:32 -
ffmpeg upgrade (includes h264 to libx264) ok with winff ?
By Verlager in forum LinuxReplies: 1Last Post: 10th Feb 2008, 17:23
