Hi everyone!
I've got a little problem with virtualdub and I need some help.
Since I've been using virtualdub I had never a problem like that.
I explain;
to make a good quality dvdrip I usually convert my movies using virtualdub in two passes, but, as a matter of fact I can't convert in 2 passes anymore.
So, I open the video file (usualy .vob), I select video, compression, XVID, configure, then I adjust the video setings in the codec, so I click "twopass - 1st pass" and I click on "more and select a proper destination for the ".pass file".
BUT, when I try to open the created ".pass file" (I mean that I select "twopass - 2nd pass and I check if the destination folder is correct)
it's not there!!! I tried to start the job without it (in the "job control"), but without success, all information I can get from VD is "error".
I've already tried everything even reset my computer but it didn't work. To tell the truth I'm kind of lost. I really don't know what to do.
Any reply is welcome.
Thanks.Death ValleyPS. My English isn't quite good cause I'm Belgian, thanks for understanding.
Using version VirtualDub 1.10.1
Encoding type > TwoPass 1st Pass > More, select name and destination of the .pass' file.
File > Queue batch operation > Run video analysis pass (this will be Job 1).
Encoding type > TwoPass 2nd Pass.
File > Queue batch operation > Save as AVI (give it a name, this will be Job 2)
File > Job Control ... It should list both of the jobs in the pane. -
OK. Thanks for answering.
I'll try that, but is it also possible with VirtualdubMOD ?
No. Not this way.
Run video analysis pass option is present since 1.6.5 version of VirtualDub.
Last VirtualDubMod build is based on VirtualDub 1.5.10 (released in december 2003).VideoAudio.pl - Serwis o technologii wideo & audio -
where is "Encoding type"? i cannot find this in virtualdub.
thanks
Handbrake encode won't start - one particular file
By Stuckster in forum Video ConversionReplies: 18Last Post: 23rd May 2013, 05:26 -
VDM Won't Encode to MP3
By adalect in forum Newbie / General discussionsReplies: 41Last Post: 24th Apr 2010, 00:52 -
virtualdub won't encode anything
By johnr283 in forum EditingReplies: 5Last Post: 17th Sep 2009, 20:33 -
FFMPEGX won't encode!
By Kalasin in forum ffmpegX general discussionReplies: 1Last Post: 26th Jul 2009, 11:02 -
help with eac3toGUI, won't re-encode file
By runLoganrun in forum Newbie / General discussionsReplies: 0Last Post: 6th Dec 2008, 17:32
