Our website is made possible by displaying online advertisements to our visitors. Consider supporting us by disable your adblocker or Try ConvertXtoDVD and convert all your movies to DVD. Free trial ! :)
  1. I am trying to create a BD that will be a collection of various video files. The menuing demands are relatively easy. I would like to have a single top level menu that allows me to scroll through the choices to pick the video I want. Chapters within the videos are not needed, nor are in-video pop-up menus. I think multiAVCHD would be good for that bare-bones description, but there is a wrinkle that has me scratching my head. In this menu, when each video choice is highlighted / scrolled to, I would like to be able to present onscreen a brief (one or two sentence) description of the video. So I have to reserve a bit of screen real estate in the menu for essentially a comments box --- easy enough, but then for each video I need to link it to the brief verbal description that would appear when it is the highlighted choice in the menu. Does anyone know of a consumer-level authoring program that can handle these per-video comments?
  2. I'm not aware of the Blu-ray format allowing you to do what you described.
  3. Member Cornucopia's Avatar
    There is no function in the Blu-ray spec that automatically creates/supports such a feature. This can of course be "emulated" in either BD or DVD by figuring out all the possible choices/options ahead of time, finding the info for them and creating "menus" with text info included in them. Whether Consumer-level or Pro-level, doesn't matter - will have to be done by hand.
    I would venture that an app could be created that generates menus with the text provided by tags or comment fields or a spreadsheet/database, but there is such a rare need for this specific kind of app, that I believe YOU would be one of the few benefitting from it. Since DVD and BD already have a strict subset of possible codecs & settings, so you already kind of know what you're getting, and it is already guaranteed to work with your player.
  4. You can't just create the comments at the beginning of each video - encode a 2-second long video with text and append it at the beginning of a video?
  5. I think Scott is talking about the "switched menu" technique - it can be done but the downsides are audio is interrupted, and switching latency can be high (it depends on specific player model)
  6. Originally Posted by vance003 View Post
    Consumer level? No way.
  7. If your original videos where .mpeg2 files you could drop them into Womble Mpeg Video Wizard as it has a fairly good Title function. What I do is I drop the video on the timeline, then I select Location and Duration. Then I make sure I select Frame and input 151 into the box. This way I can put a five second title that I created onto the title line. The five second title takes up exactly 150 frames.
    I suppose what you could do is create a blank .bmp the size of the video frame of the video you are working with. I have done this in the past, but I am drawing a blank exactly how I did it. I know somehow I used a program to stretch that .bmp after I put the appropriate text on it, to the duration of 5 seconds. Then I looked at the exact specs of the file I wanted to append it to and made sure I encoded the .bmp to become a .avi or whatever that matched for bit rate, ect. Then if the files were the same type I would append them together using AviDemux.
