Thanks for the contributions to this forum, I've spent the past few days reading-up and learning in here. A great collaborative source of knowledge.
My issue: I have CCTV footage that is extracted to an avi file that is encoded using a proprietary VfW codec. My goal is to take make this footage readable in ffmpeg - to put it in H.264 or other web format. The VfW codec obviously isn't built into ffmpeg so I read that an easier solution to adding a new codec to ffmpeg's avcodec library is to use a frame-server like AVISynth to play the files frame by frame and pass them to ffmpeg. My AVIsynth command plays the file properly in WMP but when I try to pass that file in ffmpeg I get the following error:
Code:c:\FFMPEG\bin>ffmpeg -i "input.avs" -r 1 -t 4 image-%d.jpeg ffmpeg version N-39267-g4082198 Copyright (c) 2000-2012 the FFmpeg developers built on Mar 25 2012 20:28:42 with gcc 4.6.2 configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-ru ntime-cpudetect --enable-avisynth --enable-bzlib --enable-frei0r --enable-libope ncore-amrnb --enable-libopencore-amrwb --enable-libfreetype --enable-libgsm --en able-libmp3lame --enable-libopenjpeg --enable-librtmp --enable-libschroedinger - -enable-libspeex --enable-libtheora --enable-libvo-aacenc --enable-libvo-amrwben c --enable-libvorbis --enable-libvpx --enable-libx264 --enable-libxavs --enable- libxvid --enable-zlib libavutil 51. 44.100 / 51. 44.100 libavcodec 54. 12.100 / 54. 12.100 libavformat 54. 3.100 / 54. 3.100 libavdevice 53. 4.100 / 53. 4.100 libavfilter 2. 65.102 / 2. 65.102 libswscale 2. 1.100 / 2. 1.100 libswresample 0. 10.100 / 0. 10.100 libpostproc 52. 0.100 / 52. 0.100 [avs @ 0000000001DBEB10] AVIFileOpen failed with error -2147221164input.avs: Ope ration not permitted c:\FFMPEG\bin>
My AVISynth code for input.avs, which plays the video successfully in WMP is:
Code:DirectShowSource("examples\MN_Sample1.avi", audio=false, pixel_type="RGB", convertfps=true)
1) is this the best way to get this proprietary data into ffmpeg
2) if so what am I doing wrong? Why doesn't ffmpeg read it?
I am using AVISynth
Thanks in advance
Try using the full path to the video file, not just a relative path. Or put the AVS script in the same folder as the video file and use just the file name.
Hey jagabo,
thanks for the response. Turns out the issue was my silly mistake - I was using a 64bit version of FFMPEG and a 32 bit version of AVISync.
I downloaded Zerano's 32-bit static build and retried. It worked - I DID have to use the full-path or keep the files in the same directory though - so you WERE right about that.
Mike
AVANTI - FFmpeg/Avisynth GUI (support thread).
By Chris K in forum Video ConversionReplies: 1189Last Post: 12th Jun 2017, 12:39 -
How to transcode proprietary VWV1 video to h264?
By p.w in forum Video ConversionReplies: 3Last Post: 3rd Mar 2010, 16:42 -
Transcoding audio -> ffmpeg - besweet - avisynth?
By wiseant in forum AudioReplies: 4Last Post: 18th Dec 2009, 22:14 -
{/a6} coding in ffmpeg?
By misook in forum MacReplies: 0Last Post: 14th Nov 2009, 13:57 -
AviSynth: script command, order of execution, and 'coding efficiency'
By hollowman in forum Newbie / General discussionsReplies: 6Last Post: 27th Aug 2008, 23:44
