Hi,
I've tried various applications, but they all seem to be missing something. What I'm trying to do is convert my MKV collection to MP4. I need the following features however:
- Maintain Original frame rate
- Maintain Original frame size
- Adjustable bitrate (so I can get the best possible playable from an XBox as a media center extender)
- Ability to select subtitle track (e.g. For Avatar when the na'vi are speaking their own language
- 5.1 audio so I can still play on my main PC.
I have tried the following:
AiseeSoft -> Cant keep original resolution
AVS Video Converter -> Crashes
Pavtube -> Cant select subtitles
SoThink Video -> Cant select subtitles
Leawo -> Can't select 5.1 Audio (probalby not supported)
Any Video Converter -> Doesn't support 5.1 Audio
Please could someone let me know of any applications that I could use to achieve this? I'd like to try a few to see what's best for me.
Results 1 to 10 of 10
And why not just de-mux (MKVExtractGUI2) and mux (MyMP4BoxGUI) ?
No quality loss. Fast -
Hi Guys,
Thanks for the replies. I've just tried MKVToMP4, but it doesn't seem to show me the subtitles. MediaInfo shows it as having 2 text streams. In some of the other apps I tried I was able to select which stream I wanted. Am I missing something?
I havent tried MKVExtractGuiv2 and MyMP4BoxGui yet, but will give them a go later -
Is there a really and truly compelling reason for this conversion that is not one of the following?
1) You think MP4 is "better" than MKV. Or one of your "friends" told you this and you believed them (sucker).
2) You're too cheap to buy something that can handle MKV.
You do understand that the MP4 container has limitations, right? DTS is NOT supported. AAC and AC3 are it as far as audio goes. You're already posting about serious subtitle issues (we got a lot of posts about that with MP4 files) - is there really no way that MKV cannot work for you? -
Probably because he's using an xbox for extender (limitations on formats and bitrates for mp4)
- Adjustable bitrate (so I can get the best possible playable from an XBox as a media center extender) -
I have been using MKV up to date and they have been fine as they are all run on Windows 7 Media Center. The problem is that I now wish to use my xbox as a media center extender. I have tried multiple MKVs that I have and they either stutter, refuse to play or play in very poor quality. I checked online and people recommended using MP4. I tested this with a few different conversions to MKV (Either in stereo or without subtitles) and they played flawlessly, thats why I want MP4.
If you can recommend a way I can reliably get the XBOX to play MKV then I'd be happy for some advice.
BTW: XBox is the slim model connected by 1gb LAN
which 'create DVD from MP4" app for Mac that takes any kind of MP4?
By callagga in forum Authoring (DVD)Replies: 1Last Post: 25th Jan 2012, 20:46 -
ez app to clip AVC MP4 file?
By nonexistent_entity in forum Newbie / General discussionsReplies: 1Last Post: 12th Sep 2011, 12:22 -
Is there a virtualdub like app that works with mp4/x264/aac output?
By moocowz in forum Video ConversionReplies: 9Last Post: 6th Jun 2011, 14:18 -
MKV with subtitles to MP4 with subtitles
By Evertype in forum Video ConversionReplies: 10Last Post: 6th Feb 2011, 14:43 -
The Best Xbox 360 and PS3 mkv video converting to mp4 App.
By spyder7777 in forum Newbie / General discussionsReplies: 0Last Post: 11th Apr 2009, 05:55
