dear brothers, i need a video mixer for live mixing two or three cams. please tell me which company is better. my requirements are: good quality output, video effects, microphone input slot (either stereo or XLR ), not much expensive, small in size so that is easily portable. please help me if anybody has some information.
what type of cams? what type of video inputs? tricasters were good but not cheap for SD work.
If you're doing analog SD the Panasonic 'MX' series of mixers are pretty good, and readily available used. I've used the MX 20, MX 30 and MX 50 and they were all pretty good.
HD cams like HDR-XR500E , HDR-TD20VE (not exactly these cam have to be used. these are only to to help you understand my question) etc. . i want to record output on a dvd direct in a dvd recorder or give output to computer and capture. cams will be used for example in a function to take different poses of the performer and audience. input is from cam using A/V cable from the given slot in the cam .
I don't know about mixers, but most home-level DVD recorders sold today are not HD. With an HD cam you'd need something portable like the SONY HVRDR60 ($1700). These and mixers are usually sold thru business communications and surveillance vendors AFIK. If you want "cheap", I suggest you rethink the idea.
Connecting a Video Mixer
By eightandahalf in forum Newbie / General discussionsReplies: 2Last Post: 19th Dec 2011, 10:32 -
Video Mixer or fader
By bbbrown555 in forum Newbie / General discussionsReplies: 3Last Post: 10th Feb 2011, 15:30 -
DIY Video Mixer? Can this be done with WinPC?
By tedbragg in forum Capturing and VCRReplies: 2Last Post: 13th Nov 2008, 22:57 -
Video Mixer/Switcher
By max67 in forum Software PlayingReplies: 1Last Post: 16th Jun 2008, 10:51
