Right now My site is streaming at 640x480/2000kbps/128-192kps audio, I use adobe flash encoder, iTunes, and a screen capture program. When I try to stream at 720p the video becomes off sync with the audio. What are the proper settings for streaming at 720p?
The proper bitrate is the bitrate required to achieve the quality you want, or the max bitrate your site can stream, whichever is less.
ffmpeg: best possible quality for 720p h264(mp4), bitrate under 2 mbps
By lisx in forum Video ConversionReplies: 0Last Post: 1st Aug 2011, 15:56 -
Using MeGUI downscaling to 720p. What are proper settings ?
By mahogany in forum Newbie / General discussionsReplies: 0Last Post: 1st Nov 2009, 20:40 -
Is it possible to convert 720p video to 624x352 with no quality loss?
By Chrushev in forum Video ConversionReplies: 30Last Post: 24th Oct 2009, 01:54 -
UNDERWATER VIDEO - Should I get a still-cam with 720p, or a 720p camcorder?
By v1ru5 in forum Newbie / General discussionsReplies: 1Last Post: 25th Aug 2009, 03:49 -
Quciktime movie for web streaming - what bitrate and quality?
By Bansaw in forum Newbie / General discussionsReplies: 2Last Post: 4th Sep 2007, 07:18
