So, I would like to know if I can record HD using a Hauppauge HD PVR while playing on a standard tv in sd using the following method described below.
1. Buy 5 "1 female to 2 female splitters"
http://www.ebay.ca/itm/2X-New-1-Female-2-Female-RCA-PLUG-AV-Splitter-Adapter-/18090464...d=366112704947
2. Buy 2 "component/audio cables"
http://www.ebay.ca/itm/3FT-5-RCA-Component-Video-Male-A-V-Cable-Audio-5-RCA-DVD-VCR-TV...ht_2926wt_1014
3. Buy 1 "component to composite converter"
http://www.ebay.ca/itm/250908076644?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649#ht_6446wt_800
So, finally. Let me explain.
1. Connect the xbox component/audio cables to the 5 splitters "1 input side".
2. Connect the 2 component/audio cables to the other side of the splitters "2 input side"
3. Connect one of the component/audio cables directly to the Hauppauge HD PVR with the xbox set to 1080p for HD Recording.
4. Connect the other component/audio cable to the converter and convert signal to av or s-video and hookup to standard tv.
Now, to make it less confusing I left out the purchase listing for the final items you would need to make this work properly in which would be 2 more "1 female to 2 female rca splitters" so that you may make another split for audio to your standard tv. AND, of course the s-video or yellow av cable to conect the converter to your tv.
So please tell me what you think. Please, no comments such as screw that, just by an HD TV, because I don't want one. My standard TV is a tube/flat-screen standard definition. I can't seem to play on anything but it, I have played on my brothers HD TV and various others. I just want to know if this will work or not, thanks. And I don't want to spend the money
			Closed Thread
	Please don't cross post. Continu in https://forum.videohelp.com/threads/347764-Please-READ-Can-I-record-HD-on-a-Hauppauge-H...57#post2175057
  Please READ: Can I record HD on a Hauppauge HD PVR and play in SDBy un4gettable47 in forum Capturing and VCRReplies: 6Last Post: 21st Jul 2012, 22:18
  Is it possible to record netflix streaming w/ Hauppauge 1445 HD-PVR?? Help!By eagles94 in forum DVB / IPTVReplies: 13Last Post: 9th Apr 2012, 11:00
  Is it possible to record an AVI or MPEG with the Hauppauge 1212 HD-PVR?By Daniel_BMS in forum Video Streaming DownloadingReplies: 1Last Post: 17th Aug 2010, 02:25
  Hauppauge HD PVR or HAVA Platinum HD to record PS3 GamesBy leandrokoiti in forum Capturing and VCRReplies: 9Last Post: 20th Feb 2010, 09:37
  hauppauge pvr 150: Need REAL software to recordBy SignedupGuest in forum Capturing and VCRReplies: 16Last Post: 19th Feb 2008, 13:40
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
			 Visit Homepage
				Visit Homepage
