I'm trying to play with some 5.1 audio from a blu-ray that I'm ripping but I keep on getting the audio in French instead of English. I don't know why french is the default but how can I fix it? I have a m2t file now with the 5.1 audio in french, I have heard of de muxing but I don't know how to use it or if it would help?
Any suggestions?
Thanks!
If you have to ask how to use txMuxeR to demux then you might as well give up. You aren't up to the task of doing this ...
Give up? Never.
Considering I just "guessed" how to use the software correctly without ever seeing it.
Plenty of other rips have worked without any problems. This one disc has been giving me problems. Demuxing the HD 5.1 audio tracks with tsmuxer gives me a track with no audio. The second 5.1 track gives me french only.
I'm all ears for any HELPFUL info. -
I'm guessing the HD 5.1 is the English track and that your computer can't play HD audio (I know some hardware has trouble with Dolby TrueHD and DTS HD-MA).
When you demux the HD audio you have a choice of demuxing the "core" part of it which gives you a standard 5.1 audio track. I think txMuxeR calls this "downconvert". I'd try that.
Hey thanks, choosing to downconvert the HD 5.1 audio to AC3 worked beautifully. I now have the english 5.1 audio.
Thanks for the Help!
ripping audio from blu-ray
By illyad in forum Blu-ray RippingReplies: 3Last Post: 25th Nov 2011, 08:48 -
Ripping a Blu-ray and M2TS is in French... help
By Quartechs in forum Blu-ray RippingReplies: 1Last Post: 25th Jul 2011, 14:02 -
Out of sync audio when ripping blu-ray film
By Odaik in forum Video ConversionReplies: 3Last Post: 12th Jul 2011, 13:14 -
Forced subtitles english Blu Ray Avatar
By Modify_inc in forum Newbie / General discussionsReplies: 1Last Post: 26th Apr 2010, 23:31 -
Ripping Audio streams from Blu-ray?
By MrBlueSky in forum Blu-ray RippingReplies: 3Last Post: 10th Feb 2010, 17:10
