Got myself JVC HM-DT100U D-VHS unit to transfer some tapes using firewire connection. For some reason I was thinking that it would transfer in DV/AVI format. But the native transfer format when using a regular VHS tape, appears to be MPEG2 9550kbps video, MPEG Layer2 384Kbps Audio, and a 2nd 1920Kbps PCM audio track. Is anybody familiar with these D-VHS units?
Is there a way to tweak the video bit-rate as high as possible?
I believe that I'm noticing small compression artifacts during fast movement.
HDMI output gives lots of aliasing even when I try to tweak video options. My solution so far is to capture the video using component output to lossless or at least DV, and then encode to AVC/MPEG4 with quality deinterlacing and stuff like that...
Any helpful thoughts will be appreciated.
Thanks.
	The manual says that Firewire OUT is MPEG2....and 9550kbps with PCM audio MIGHT already be over official DVD specs anyway.
 http://support.jvc.com/consumer/product.jsp?modelId=MODL027315&pathId=50&page=3&archive=true
 I've captured to 12,000 with my Hauppauge PVR-350 but that is terrible overkill....after all this is VHS we are talking about here.
	In the usual sense yes. But I managed to work some magic with avisynth; few corrections, quality de-interlacing and little upscaling. Which is the main reason I need at least near lossless capture. The final result is a lot better than when viewing the original tape. DVD MPEG2 spec seems to not able to handle smooth 100% artifact free video.
  JVC HR 9600....edit mode vs auto mode for digitizing s vhs or vhsBy fuzzblaster in forum Capturing and VCRReplies: 21Last Post: 21st Jan 2011, 09:28
  JVC Svhs 3900 picture settingsBy cyber-junkie in forum Newbie / General discussionsReplies: 0Last Post: 12th Jan 2010, 19:38
  JVC HM-DT100U – is there a European equivalent?By marada in forum RestorationReplies: 7Last Post: 16th Dec 2009, 12:07
  JVC SR-MV55US - Users with Experience with JVC Professional S-VHS/DVD DecksBy Anonymous4 in forum DVD & Blu-ray RecordersReplies: 6Last Post: 21st Aug 2008, 16:23
  JVC Picture Settings - Auto, Edit, Soft, Sharp (pictures)By BrainStorm69 in forum RestorationReplies: 7Last Post: 7th Aug 2008, 08:46
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
