Ok, now I have an MK3D file (thank you to all who helped), and no player on my PC (which has 3D capabilities) for it. Any good players that support MK3D? Do I have to change the filename?
Also, is it possible yet to create a 3DBD?
MKV: Merely Krappy Video.
Subbers, a request from an avid viewer: Either don't use mkv, or supply avi or mp4 as an alternative.
For those frustrated with converting MKV: http://www.immortalmusic.net/mkv/ -
That's an MKV file.
http://3dvision-blog.com/tag/mk3d/
Any player that plays MKV should be able to play the file. You may have to associate the player with the extension. Or just manually use File -> Open to play the file. Or drag-and-drop the file onto the player. I don't know which players support stereoscopic playback though.
I've read that Power DVD, VLC, and Arcsoft Total Media Theater support it. I played a sample with 3840x1080 side-by-side 3d with VLC and MPCHC. But having no 3d hardware it just shows up as one big picture.
The Popcorn Hour appears to support MK3D.Last edited by jagabo; 18th Jul 2012 at 20:00.
1. The "3d" bluray described in the previous post is NOT a true, BD3D spec disc. It's just a standard bluray disc with a 2d video encoded on it that happens to be in Side-by-side arrangement format.
This will work in 3d as long as you MANUALLY set your 3dtv into 3d mode. Just know that you're getting slightly less than HALF the quality of a FullHD BD3D format.
2. Yes, (NOT counting Anaglyph, or Crosseyed/parallel freeview) you must have a real, true 3d display (and glasses) to see 'em in 3d.
3. Assuming they're standard layout format (sbs, t/b), mk3d can be output by any regular media player. Stereoscopic player may be able to assist with 3d IO options, though.
Scott -
No, they don't support automatically adjusting their interpretation of the stereo layout BASED ON the mk3d flags, but it's easy in either player to manually set that, so they CAN be used to play 3D!
ScottLast edited by Cornucopia; 3rd Aug 2012 at 11:24.
An mk3d is just an mkv with the extension changed to make it easier for 3d-capable devices to recognize the content as 3D. If you want a player which has support for "mkv", but not "mk3d", to be able to see it, just rename the extension. No conversion necessary.
However, that doesn't say anything about whether or not your player(s) can support the material that is encoded on that mk3d file. Could be layed out in a number of ways: dual-stream, Side-by-Side (sbs), Top-and-Bottom (tab), etc. Some are naturally 2D-compatible, some (most) are not.
If they aren't, then what you do next depends on how it IS layed out and how you want to view it (in 2D? or in 3D?)...
Use a detailed MediaInfo text readout to show how the file is layed out (it will say MultiView_Count:2, MultiView_Layout:...)
Can i burn avi/mp4/mkv etc to blu ray media and play it in a blu ray player
By brad350 in forum Newbie / General discussionsReplies: 10Last Post: 21st Apr 2012, 05:15 -
Wanna convert Blu Ray Movie to Play on Laptop/PC without a Blu Ray PLayer !
By augustya in forum Blu-ray RippingReplies: 5Last Post: 13th Aug 2011, 04:35 -
Copyed Blu ray won't play in blu ray player
By gweedow in forum Video ConversionReplies: 6Last Post: 13th Jan 2011, 15:58 -
Convert .MKV to .MTS (AVCHD) for use in BD 35 Blu Ray player
By NirvClub in forum Newbie / General discussionsReplies: 7Last Post: 7th Feb 2009, 16:51 -
My Sony Blu-ray player BDP-S1 does not recognize my Blu-ray Disc
By showgirl in forum Newbie / General discussionsReplies: 5Last Post: 2nd Oct 2007, 13:48
