I need a camera that will both record and put out a live video feed at the same time if that is possible. We need to record services for the sick as well as send a video feed to the nursery and over flow rooms. Is there a camera that while do this and should I be looking at other options? Not looking to spend more than absolutely necessary on that project as we are a small country church.
Do you plan to broadcast your video (wireless) to other rooms or do you intend to string cables?
Wireless is the way I would go but it will be costly. -
I haven't decided for sure. Most the wireless seem to be limited to about 100 feet so I have to check into that. Just trying to find a camcorder that will record while it is outputting to the distribution system.
Why not output the camera into a chain of hardware, and record with something inline that way?
Lots of large churches dump to a DVD recorder while also playing on the big screen behind the pulpit.
It gets more complex with HD.
(Most of the videos just end up online anyway, and are not required to be in HD.)Want my help? Ask here! (not via PM!)
Multi-camera set up procedure + Q's
By James Hester in forum Newbie / General discussionsReplies: 0Last Post: 5th Sep 2011, 11:51 -
Multi camera editing software
By woodnote in forum EditingReplies: 4Last Post: 29th Aug 2011, 20:41 -
Multi Camera Online Streaming Help - HELP!
By JimmyF in forum Video Streaming DownloadingReplies: 0Last Post: 21st Mar 2011, 11:07 -
Multi camera video capturing
By atwwork in forum Capturing and VCRReplies: 0Last Post: 7th Sep 2010, 20:17 -
Multi-Camera Capture Video Church Service
By kevin.handley in forum Newbie / General discussionsReplies: 5Last Post: 28th Dec 2008, 21:36
