Hi !
I wonder how I can tell if my video conversion/encoding is limited by my CPU or HDD ? When I do a encoding, I see if the CPU is 100%, if 100%, then it means that I've max out my CPU ? If not 100%, then I can assume it due to HDD and I can improve the speed by using SSD ?
If I have not enough HDD space and I use my NAS which is attached via Gigabit Lan, is that acceptable ? It seems like it does not take a lot longer using NAS.
Thanks...
	Unless you are converting from uncompressed or losslessly compressed to uncompressed or losslessly compressed the hard drive isn't the limiting factor.
 Seeing less than 100 percent CPU usage isn't really an indication that the CPU isn't the limiting factor. Many programs are still singled threaded. On a quad core CPU they will max out at about 25 percent CPU usage.
	I copy the DVD files to my harddisk and then convert them to MP4. Is that considered uncompressed / lossless ? Thanks.
	A SSD will speed up many things, but cpu intensive stuff like converting dvd to mp4 video is not among them.
	For video encoding/conversion, the most important parts are CPU and RAM
  Anybody Use An SSD?By Ron B in forum ComputerReplies: 16Last Post: 29th Jan 2011, 17:21
  SSD (Solid State Drives) for Encoding?By ajgoyt in forum Video ConversionReplies: 6Last Post: 8th May 2010, 15:31
  Any Recommended HD subcompact SSD 'flip' video cams??By stedyone in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 26th Sep 2009, 02:01
  SSD Awesomeness!By Browncoat in forum Latest Video NewsReplies: 4Last Post: 7th May 2009, 02:12
  Trying out a SSDBy redwudz in forum ComputerReplies: 15Last Post: 5th Apr 2009, 16:15
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
						 Visit Homepage
				Visit Homepage
