well let me start by saying thanks to everyone who has helped me .. thats noone by the way.. im a newbie just starting out ive asked 2 questions and not got one answer ... way to help someone who needs help.. well i wont be comeing back here anymore .. so put any reply u want underneath cos i wont be seeing it after today ..
Monkey Tennis should now be a global sport..
your are welcome for thanking us. AND R U A JACKASS , STOP CRYING AND IF U WANT TO BE HEARD RAISE SOME HELL ON THIS BORAD. DRINK A FEW BEERS. EMAIL THAT BALDDICK.. AS HIM FEW QUESTION. STOP SULKING LIKE IF UR A ABOUT TO DIE
For your first question, I think the problem is you didn't really explain your problem. And your paragraph is extremely hard to read because you never use capital letters or periods... your whole sentence is just one thought constantly flowing. To be honest, just to understand your problem took me three times reading through it, which is more than I ever usually do. I usually read through it one time, if I know the answer I'll post it, but if I'm not clear as to what the problem is, I'll skip it. Maybe if you explained exactly what you're doing, what programs, what exactly your problem is, people would be able to give you more help.
For your second question... all you say is that you can't rip movies. You don't say what program you're using, what your computer specs are, any other information that might give us a clue what your problem is. It could be that your computer is slow. It could be that you have a software conflict. It could be that you have an older version of a program. It could be thousands of things... without a clearer idea of what's wrong, we can give you any help.
Plus here's another option. Have you tried searching the forums for your answer? You said in your first post that you had a problem with making menus... there are tons and tons of posts about making menus. They could have recommended to you different problems to make the menus with, and you could learn from the mistakes of others. I'm imaging you didn't try this because you said in your post you only tried one program one way and didn't try anything else.
And the fact that you post here basically yelling at us for not helping you when you didn't take the time to help yourself first makes no sense at all. I'm typing this so you'll consider some other options before just up and leaving here. I can guarentee you that you're not going to find help anywhere else on the net like you can get here. VCDs are very frustrating when you first get started... so just take a deep breath, organize your thoughts, look for answers, then post a detailed question including your computer specs, the programs you're using, and exactly what's going wrong. Break your question up into sentenses, and space out your paragraphs by hitting the enter button twice. Also, try writing more informative subject headings than "protection or something". Many people here only browse through the titles of subjects to see what they could help with. I don't know anything about protecting a VCD, so I skipped your post... and you weren't even asking about protecting a VCD. If you wrote a subject line like "Ripping CD causes XXXX program to Crash", I bet you'd get more responses.
Good luck in the future... follow these steps and I bet you'll get more help. And ignore posts from someone like Hitmandj. Someone like that is more than likely just going to eventually get banned, no sense dealing with them. Ignore the bad and keep searching for the good. Good luck, and feel free to post again if you have any questions. -
or maybe no one knows the answer.
Look at the number of views as well as replies.
If there r alot of views but no replies, i would bet the people just don't know the answer.
And most of us aren't trained professionals so we won't know everything.
Any Vancouver Olympic observations? 1080i 29.97 sure helps here vs 25.
By edDV in forum Newbie / General discussionsReplies: 6Last Post: 28th Feb 2010, 19:57 -
Really need some serious helps with DVD Shrink!!!
By coxanhvn in forum Newbie / General discussionsReplies: 13Last Post: 4th Jul 2009, 07:31 -
I killed my GSA-H22N LG driver!!! Please, somebody helps!!
By Bruxo in forum DVD & Blu-ray WritersReplies: 7Last Post: 13th Oct 2007, 17:22 -
Sorenson Sq 4.5 Crashes - My Firstborn for anyone who helps!
By CLE in forum Video ConversionReplies: 3Last Post: 29th Aug 2007, 09:23 -
Helps with Magnavox dv200mw8
By mairel in forum DVD & Blu-ray PlayersReplies: 0Last Post: 7th Jul 2007, 11:36
