I am looking for USB 3.0/USB 2.0/SATA cables. Raw cable with no ends. I need short lengths though 5 x 6ft. I do not want to buy 100' or 1000' rolls.
If anyone has suggestions, please let me know.
gary
Unless I'm mistaken, they don't sell them that way.
Plus, there's a length limit for them anyway (5 meters, 5 meters, 1 meter respectively).
Scott -
Well they make SATA cables over 3 feet or 1 meter,
http://www.newegg.com/Product/Product.aspx?Item=N82E16812117651
http://www.newegg.com/Product/Product.aspx?Item=N82E16812117657
So I do not think there is a 1 meter (roughly 3 feet) limit on SATA cables.
And I am pretty sure USB cables can run longer than 15'....
I seem to recall some time back where they could run 25' with no signal loss.
But I have never seen SATA or USB cable in 100' or 1000' rolls with no ends!!!
Not saying it does not exist, I just do not recall ever seeing it....
And if you only want SATA cable or USB cable in 5'-6' in length, break out the crowbar and break down and spend the whole $3.50 - $5.00 and buy a 6' SATA cable and cut the ends off
But what's the point ?
You will just have to ad the plugs to the end of them anyways...... -
Why do I get the feeling another firt-time-poster will be along shortly with an answer in the form of a link?
How do you store your audio/video cables? And computer cables as well?
By yoda313 in forum Newbie / General discussionsReplies: 12Last Post: 29th May 2012, 13:19 -
Are RCA/composite video cables compatible with audio cables?
By sldvd in forum Newbie / General discussionsReplies: 5Last Post: 15th Aug 2011, 00:17 -
Extension cables vs Replacement cables
By Novice20 in forum Newbie / General discussionsReplies: 4Last Post: 26th Jul 2011, 20:03 -
dv cables
By rizvi in forum DVD & Blu-ray RecordersReplies: 2Last Post: 24th Mar 2009, 02:44 -
HDMI cables - anything I should know?
By lordsmurf in forum Newbie / General discussionsReplies: 17Last Post: 7th Nov 2007, 13:13
