It looks like you didn't use deflicker or the temporal chroma noise filtering from the script I posted earlier.
Results 31 to 33 of 33
yeah........
but there was so much noise i was getting in.
i couldn't get rid off it....... i dnt know where i was getting wrong -
Some of the flicker is pretty severe in that clip. You'll have to crank up the Deficker settings to reduce them. Unfortunately, that may mean that leave you with pumping brightness at scene changes.
possible to fix vertical color stripe?
By spiritgumm in forum Video ConversionReplies: 6Last Post: 25th Apr 2012, 09:35 -
color changes in old tape...way to fix?
By snafubaby in forum Newbie / General discussionsReplies: 4Last Post: 15th Mar 2010, 04:07 -
Estimates of labor and parts to fix color of Sony HDTV
By edong in forum Newbie / General discussionsReplies: 11Last Post: 28th Nov 2008, 23:41 -
Change from a color to another in a video
By Nokiamania in forum EditingReplies: 4Last Post: 7th Jul 2008, 02:51 -
ConvertXtoDVD - Can't change subtitles color
By Phil240 in forum Authoring (DVD)Replies: 5Last Post: 8th Dec 2007, 04:03
