Hi,
I'm a beginner when it comes to video editing.
I managed to create an movie out of an animation (iClone 5). While exporting from iClone5 there are a few compression methods that I can choose(so if one of them is too restrictive maybe I can try another one).
I would like to add, at the end of this movie, a few slides, with some explanations (only text on the slides) and audio (recorded voice of somebody). Each slide/scree/frame/ should last for as long as the recorded voice for that slide is playing (around 10-15 seconds).
Would it be better to make one recorded audio to be played over multiple slides? I guess it would remove the unpleasent stop/start break...
Can you please recommend me a software that I could use?
Thanks,
Jimmyy
Need Basic Video Editing Software - PC
By Bascotie in forum Newbie / General discussionsReplies: 7Last Post: 12th Feb 2011, 07:15 -
Do you use premium video editing software or basic packages?
By yoda313 in forum PollsReplies: 23Last Post: 6th Oct 2009, 13:02 -
Can Anyone suggest some REALLY REALLY basic easy editing software
By Jan29 in forum Newbie / General discussionsReplies: 7Last Post: 20th Jan 2008, 21:04 -
Best / Basic Video Editing Software
By oztek in forum Newbie / General discussionsReplies: 5Last Post: 12th Jan 2008, 21:29 -
need a basic video editing software to import youtube vids. (not wmm)
By jaiyen in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 8th Oct 2007, 16:59
