I have few tutorial dvd / movies with NRG extention file.
Was wondering if I can convert it to Divx, Mkv or Avi
or can I also burn it direct?
The problem is, I dont feel like installing new / another program, so would be great if my existing program can do this.
This is some of the programs I have:And if I want to just convert it, how can I see the original pixel size of the video files?
- Vidcoder
- Windows DVD maker
- Corel Video Studio
- Cyberlink Dvd Suite
- Divx Plus converter
- Free Studio Manager DVDVIDEOSOFT
- ImToo DVD copy express
- Iso Image Burner
- Real Player Sp
- Roxio Creator 2012
Thanx
Results 1 to 10 of 10
I did try to convert it to Mkv using free studio manager.
It works, however... due to the video has 3 different video angle, the angle changes automatically and it changes so fast which I cannot control. I think it would be fine if the vidoe doesnt have option to change the angle though.
Dave, thanks, ill try to mount it with iso image burner and see if it works -
Thanx, ill try vidcoder then
edit:
1st attempt failed, from 01.25.19, only 33 min completed (but it looks promising as I can choose the angle and the language that I wanted)
now im trying to do it again, if it fails then I guess i hv to break it down to smaller size, maybe 1 chapter at a time.Last edited by rronald_25; 18th Jul 2012 at 09:58.
Hi Baldrick,
I tried vidcoder and handbrake both cant complete the task.
Vidcoder says failed and when i play it only 33min played from 1.25.19
Handbrake also the same only able to convert 18min but it says completed
Do you think its possible to just explore the disc and get the video_ts & audio_ts files that I want? then maybe combine it with some programs? -
On quite a few of these apps, opening the IFO related to the main title set, will include all the relevant VOB's.
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 11:19 -
MKV to AVI direct stream copy problem...
By zovx in forum Video ConversionReplies: 26Last Post: 25th May 2011, 08:14 -
direct stream copy of a mkv file Q
By Information in forum EditingReplies: 5Last Post: 20th Jul 2009, 14:06 -
VHS to DivX direct?
By blackice in forum Capturing and VCRReplies: 1Last Post: 23rd Sep 2007, 17:34 -
Capture / Burn direct to drive
By Bob08 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 19th Jul 2007, 15:28
