I'm trying to work out how to capture the Breaking Bad podcast, for episode 501 found at
http://www.amctv.com/shows/breaking-bad/insider-podcast-season-5
Last year I could use Stream Transport but I can't get it to work now.
It should be just MP3 in Flash, I want it as a native FLV.
I know I can just set it playing and record it, but would prefer to get it in the original format.
And I know it's on iTunes, but I can't use that.
PS -- Am using IDM now and it seems to be working, can't be sure till it's finished, which will take an hour (it streams in real time).
Hi
RTMPDump will download that podcast (quickly).
Maybe RTMPExplorer would do the job too with Windows. -
Thanks. the hard part is finding the rtmp URL.
How did you do that?
IDM found it, when a few other tools failed.
I can't run RTMPExplorer as I don't have .NET 4.
Podcast Audio Splitter(help)
By hellfire45 in forum AudioReplies: 5Last Post: 23rd Oct 2009, 15:30 -
Capturing for podcast.
By latr0486 in forum Newbie / General discussionsReplies: 2Last Post: 27th May 2009, 19:58 -
Populating empty ATI VIP / AMC feature header on AIW Rage 128 Pro
By cybertheque in forum Capturing and VCRReplies: 3Last Post: 14th Sep 2008, 15:36 -
I just listened to my first podcast - cool!
By yoda313 in forum Off topicReplies: 3Last Post: 26th Sep 2007, 16:17 -
Does simultaneous computer usage affect capture quality w/USB capture?
By miamicanes in forum Capturing and VCRReplies: 3Last Post: 19th Sep 2007, 18:05
