I use an rechargeable razor.
Results 1 to 20 of 20
Corded, but it's not doing the job as well as it used to. We'll see what I'll get for a replacement.
Double edge safety razor, a horse hair lathering brush and old fashion (squeeze tube) shaving cream or shaving soap cake depending on my mood
--dES"You can observe a lot by watching." - Yogi Bera
http://www.areturningadultstudent.com -
Beard, kept in control with hair clippers.
Perma-shadow.
Voted for hair removing cream just to be silly.
Old-fashioned injector single-blade safety razor. (The refills are getting hard to find). And shaving soap with horsehair brush.
Pull! Bang! Darn! -
Maybe the poll should havebeen ...what part of the body do you shave ?
I use a safety razor, and old Gillette adjustable from the 60's, works like a charm.
I also use an older Gilette safety razor from the 70's, but that is an non adjustable.
Have 3 different shaving brushes, one with boar bristles and two with badger hair
And I use and alum block after shaving and I splash on some Tabac aftershave and I'm good to go
Razor blades, brushes and shaving soap/cream are easily obtained from ebay and other web shops
I would recommend taking a visit to the badger and blade forum, for reviews, buy, sell and trade of shaving gear -
I have my Grandfather's Gillete Razos, one adjustable, one Not, but I can't find them since we moved into our house (10 years some things are still packed
When I got back into traditional shaving I wanted to start using them again. Now I use a Parker 82R for every day shaving and a Merkur MR500 when I need a closer shave.
Badger and Blade is a great site!! Also for just starting out and over all tips Sharpologist http://sharpologist.com/ is good place to start.
Never heard about Sharpologist, thanks for the tip Des
I recommend Mantic59's videos, loads of great tips from him: www.youtube.com/user/mantic59
If you are new to DE-shaving -
Shave, What is this word Shave? What does it mean
If I'd known I was going to live this long, I'd have taken better care of myself. -
Shaving 1 or 2 pixels off an mkv (pixel and display width)
By skinney6 in forum EditingReplies: 2Last Post: 11th Mar 2012, 11:06
