OK,
So I have a budget HTPC. I finally got everytihng working on my P4 with ATI HD6570 graphics card and PowerDVD to hardware accelerate my 3D bluray ISOs. The ONLY problem I have now, is that PowerDVD does NOT give you the option to select either DTS or DD tracks for the audio. It simply outputs DTS if I select SPDIF output and a DTS track is available. The problem is, my receiver only decodes DD tracks, not DTS. I was hoping there is some way I can simply extract the DTS tracks so that PowerDVD will be forced to play the DD tracks instead, or someway to edit the ISO so that it defaults the audio to the DD track and not the DTS.
Please do NOT suggest using another player like TMT or Stereoscopic player, as I CANNOT get them to work properly. Any help would be greatly appreciated!
Results 1 to 9 of 9
best you could do is convert the iso to mkv and only include the audio you want.
Anybody? I had the thought....I could us TSmuxer to suck out the dts track...convert that to a 5.1 ac3 track and remux it back in to the m2ts file. Then overwrite the m2ts file on the iso. Would that work? Anyone have a good ISO program to replace the existing m2ts with the new one?
There are only TWO programs that I know of that do hardware acceleration of 3D blurays. TMT will hadware accelerate both 3D blurays and MKV files and PowerDVD will hardware accelerate Bluray Discs. I bought TMT only to have it continually crash on me. Doesn't appear to be very stable in playing back 3D MKVs for me. PowerDVD plays back the Ripped ISO perfectly.... except for the fact that it doens't let you choose the output track...and keeps defaulting to the DTS-HD track. Stereoscopic player has options for hardware acceleration that I could never get to work. VLC player to my knowledge, does NOT output 3D.
Sounds to me like you need to fix something(s) in your system first. Those other players should work without crashing and pdvd should play whatever is set to the "default", with both dts and ac3 able to use passthrough. Sounds like something else is conflicting...
Scott -
VLC player to my knowledge, does NOT output 3D.--
Easy way to extract (demux) audio tracks from Blu-ray folder?
By ricsee in forum Newbie / General discussionsReplies: 2Last Post: 11th May 2011, 11:12 -
HOW do I extract 1 audio track from a .ts / .m2ts with 4 audio tracks?!
By elgy in forum DVB / IPTVReplies: 25Last Post: 23rd Jan 2011, 23:28 -
Video with L/R tracks to DVD with 2 channel audio tracks
By Downloader in forum Authoring (DVD)Replies: 2Last Post: 22nd Aug 2010, 01:56 -
DVD to MPEG2, extract mult audio tracks, subtitles for replay in WD TV Live
By Jacoman in forum DVD RippingReplies: 5Last Post: 16th Mar 2010, 09:40 -
Extract / isolate 5.1 audio tracks from DVD
By soundchaser in forum MacReplies: 0Last Post: 16th Mar 2009, 12:21
