I used to use mpeg strmclp for converting video files (ie .avi to .mp4). now it seems it wont do it. it usually creates a file about 75MB or so (as opposed to the .5-2GB video files, full length movies). when attempting to open, in any media player, it just plays a black screen the entire time with no audio. i used to not have any problems doing this. i use all default settings (ie H.254, 50% quality, unscaled frame size, mp4 aac audio, etc).
any suggestions?
Do you have Perian 1.2.3 installed for .avi playback?
If you open the .avi file in Quicktime Player Pro ( Or Quicktime X)
and perform the Media Info command ( Cmd -i) what
does it say about the .avi file?
Last, does the .avi file play perfectly in VLC, or does VLC ask to repair the file upon trying to open it in VLC?"Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User -
im currently using a pc, so perian isn't applicable. i typically use vlc to watch videos without issue. when i open the converted file, however, it "plays" perfectly, meaning it doesn't ask to repair, etc, but it only displays a black screen and does not play any audio.
when attempting to open with wmp, it does the same thing as vlc. -
Lombax, you'll probably get more help in the Windows forum, since you are using a PC.
I'll ask a mod to move your post."Everyone has to learn, so that they can one day teach."
Urban Mac User -
Moved the posts to video conversion where you can get more help.
Black screen, but Audio is fine - when playing after rendering
By DUCKVILLELOL in forum Newbie / General discussionsReplies: 0Last Post: 14th Dec 2010, 06:06 -
Playing Video on display 2 and display 1 goes black
By sidewaysdriver in forum Software PlayingReplies: 2Last Post: 3rd Aug 2010, 01:36 -
wmp11 & mpc-hc display audio info on the screen for mpg,avi files
By Danneauxsvh in forum Software PlayingReplies: 4Last Post: 6th Jun 2010, 13:16 -
Black screen on second display
By cheerful in forum Software PlayingReplies: 3Last Post: 24th Feb 2010, 16:33 -
Black screen with audio in all players except WMP
By charliei in forum Software PlayingReplies: 11Last Post: 8th Jun 2009, 19:42
