Results 1 to 10 of 10
  1. i have imported supported avi file in avidemux, it is coming green video in avidemux software.
    pls help
    i have attached codec info of that avi file to this thread.
    pls help
  2. Member budwzr's Avatar
    Apr 2007
    City Of Angels
    Move the scrubber off the first frame.
  3. i Moved the scrubber off the first frame.
    but still its coming "green screen in avidemux.
    i noticed that "IV50" Codecs will not work in avidemux. is this right?
    Mar 2011
    Nova Scotia, Canada
    iv50 is an ancient indeo video codec that hasn't been supported by many people at all in ages.
    There may be an iv50 codec out there somewhere that will work in something like virtualdub that uses separate codecs, unlike avidemux or vlc.
    Mar 2008
    FFDshow supports Intel IV50; just open the VFW/video decoder (directshow) config and set it from disabled to Libavcodec.
  6. if i do like this"FFDshow supports Intel IV50; just open the VFW/video decoder (directshow) config and set it from disabled to Libavcodec"
    then i can import avi video containing iv50 codecs into avidemux without any green screen?
  7. VH Wanderer Ai Haibara's Avatar
    Jan 2006
    Somewhere on VideoHelp...
    Probably not. AVIDemux uses its own internal codecs and filters, I believe. But you can use ffdshow with VirtualDub.
  8. how to use use ffdshow with VirtualDub.
    pls tell the procedure for it.
    Mar 2008
    Download this file and extract the contents.
    http://www.virtualdub.org/beta/DShowInputDriver-0.93.zip
    Copy the \release\DShowInputDriver.vdplugin file and put it in the Virtualdub plugin folder.
    Restart Virtualdub.
    To open video files using the plugin:
    file/open. Highlight your file
    and at the bottom where it says "files of type" set it to directshow input driver"
    However, I also so noticed that Windows XP has native support for IV50, Virtualdub in XP
    can open it without any problems.
  10. Originally Posted by Ganesh Ujwal View Post
    It's the same as your earlier post set it to libavcodec in the VFW decoder configuration , except it works for vdub, NOT avidemux
