which software can allow me to add permanent subtitles to a video without re-encode,so there is no loss in output video
quality?
Results 1 to 9 of 9
It's not possible.
You can make a dvd with forced subs but some apps can still disable them. -
i cant understand the sentence "some apps can still disable them".
pls explain them. -
It's a standard dvd with forced subs but some video players can still disable them....so they aren't permanent.
but for YIFY torrents they have made permanent subtitles to a video without re-encode
how do they do?
Yes. As said above, any time you want to permanently hardsub a video, you HAVE to re-encode.
Edit: Does SubMerge do hardsubs? If not, it's not creating permanent subtitles. Instead, it's creating softsubs, which you can switch on and off.
(Haven't tried SubMerge... don't usually do much video work on my Mac.
HowTo add permanent Letterboxed subtitles to video w/ Virtualdub, SRTtoSSA
By KneeRow in forum SubtitleReplies: 20Last Post: 13th Feb 2013, 14:05 -
How can i add 2 permanent subtitles upside and downside the video?
By farzad67 in forum SubtitleReplies: 19Last Post: 6th Feb 2013, 13:38 -
How do I add permanent subtitles 720p MKV video
By Torresinho in forum SubtitleReplies: 1Last Post: 15th Sep 2011, 21:16 -
Help encode permanent subtitles and then edit DVD
By kapital in forum Newbie / General discussionsReplies: 11Last Post: 29th Apr 2008, 10:43 -
How do I add or edit permanent subtitles
By VidHunter in forum MacReplies: 19Last Post: 29th Nov 2007, 15:55
