i'm new here. i've been looking through several softwares to extract subs (or demux) from the mpg files i have. i tried tmpgenc, dgmpg, subrip, rejig and others. with one of them i tried a simple demux, and i got an error message. either i don't understand how to do it properly or they don't support mpgs. can anyone help?
ProjectX will extract subs from MPEG TS files derived from PVR's digital tv. You need to know the page number. To set the program up see my signature. However not sure from your post that says mpg's - normal mpg files don't contain subs - you need to far more specific about the source and what typle of file it is. eg VOB files on a DVD are a form of mpg and may contain subtitles - if this is the case then other software may be more appropriate.
Also if you indicate your country in your sig it will be lot easier to answer these type of questions as digital tv standards vary from country to country even in area that are nominally PAL or NTSC etc. The more information provided the better the answer is likely to be....SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
this is where i won't be very helpful. all that i know is the videos are MPG, and somebody embedded CC/subs in it. probably CC, because he kept mentioning that, and there are other versions- CC1 to CC4. definitely NTSC. the cc/subs won't load in MPC HC, only in VLC. its definitely not .vob, but dunno whether its a "mpeg ts".
Try CCExtractor then. Closed Captions are very different from subtitles. You should have mentioned it in your first post. Regular MPGs don't have real subtitles.
Get hold of MediaInfo and run the file through to get a report - use text mode and then you can copy and paste the results in a post. We can then see what type of file it is and what's in it. ie subs or cc
Extracting subs/frames in 200 DPI
By user2008 in forum SubtitleReplies: 1Last Post: 9th Sep 2010, 10:39 -
Extracting subs from MKV for iPod
By nj473 in forum SubtitleReplies: 4Last Post: 2nd Feb 2010, 13:35 -
extracting timecodes from hardcoded subs
By quzma in forum SubtitleReplies: 0Last Post: 2nd Jan 2010, 15:26 -
Extracting Subs from Subbed Videos
By un461v3n in forum SubtitleReplies: 1Last Post: 2nd Nov 2008, 11:24 -
Issue with Subs after extracting MKV file
By Alucardio in forum SubtitleReplies: 8Last Post: 27th Mar 2008, 22:34
