I have been trying to convert some MOV files from my Canon 600D DSLR camera for use in Sony Vegas Movie Studio HD 10.
The resultant files play audio in VLC player and also in the VMS10. I used the default settings.
Any suggestions as to the best settings for video quality.
Why just audio and not the video, it is in there somewhere as the file is too huge to be just audio.
This is the details on the original clip:
General
Complete name : D:\Images Travel 2012\Canon 600D\C Video Khumbu\MVI_03188.MOV
Format : MPEG-4
Format profile : QuickTime
Codec ID : qt
File size : 180 MiB
Duration : 31s 732ms
Overall bit rate : 47.7 Mbps
Encoded date : UTC 2012-03-20 10:27:23
Tagged date : UTC 2012-03-20 10:27:23
Video
Format : AVC
Format profile : Baseline@L5.0
Format settings, CABAC : No
Format settings, ReFrames : 1 frame
Format settings, GOP : M=1, N=15
Codec ID : avc1
Bit rate : 46.1 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Original height : 1 088 pixels
Display aspect ratio : 16:9
Original display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 29.970 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.743
Stream size : 175 MiB (97%)
Language : English
Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
Transfer characteristics : BT.709-5, BT.1361
Matrix coefficients : BT.601-6 525, BT.1358 525, BT.1700 NTSC, SMPTE 170M
Audio
Format : PCM
Format settings, Endianness : Little
Format settings, Sign : Signed
Codec ID : sowt
Bit rate mode : Constant
Bit rate : 1 536 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Stream size : 5.81 MiB (3%)
Language : English
Closed Thread
Continue in your first similar thread instead. https://forum.videohelp.com/threads/347606-Vegas-Movie-Studio-10-issues-with-MOV-files-...29#post2174029 . It's easier to follow what you have tried.
Why Can't I convert the whole file in mpeg streamclip?
By alphonsecpone in forum Video ConversionReplies: 0Last Post: 5th Mar 2011, 10:24 -
Help !!Convert a trp file with Mpeg streamclip
By caliman in forum Video ConversionReplies: 0Last Post: 21st Oct 2010, 12:55 -
Unable to Use Batch mode in MPEG STREAMCLIP for DVD Convert
By nimrodm in forum Video ConversionReplies: 0Last Post: 3rd Jan 2010, 09:27 -
How to convert an MPEG file to DV-AVI Type 2 using MPEG Streamclip
By MAdNEZ in forum Newbie / General discussionsReplies: 15Last Post: 4th Aug 2009, 08:30 -
How to convert video to iPod MP4 using MPEG StreamClip (free)
By Baldrick in forum User guidesReplies: 20Last Post: 6th Jun 2008, 23:48
