i have some mp4 movies and some avi movies with low audio
how can i only boost the audio without converting or re-coding the entire file !
	You can demux the files; drag the audio in an appropriate program; adjust the volumen and then mux it back together !
	Not all media players increase the volume above 100% and video isn't always played using a PC.
 Extracting the audio, re-encoding it and using the new version to replace the old is the only way to permanently adjust the volume. Yamb should extract the audio from MP4s, VirtualDubMod for AVIs. If the audio is MP3 it's volume can be adjusted without re-encoding.
 Instructions for using Yamb and VirtualDubMod would be whole topics on their own, as would instructions on how to re-encode the audio. Maybe start by installing those programs and post back for any help you may need.
	I hope you didn't think I was referring to your reply when I posted, because you're right, it's hard to know where to start when someone asks a fairly "general" question, and you can spend a whole lot of time typing instructions only to find the original poster disappears, or was looking for a program with a special "fix my audio" button
 Hence my only suggesting a couple of programs to get them started (assuming they run Windows).
	No No I don't think that. I was just bewildered. Still is.I hope you didn't think I was referring to your reply when I posted, because you're right, it's hard to know where to start when someone asks a fairly "general" question, and you can spend a whole lot of time typing instructions only to find the original poster disappears, or was looking for a program with a special "fix my audio" button
  Trying to enhance Flip Ultra Camcorder MP4. Need help.By Nagashi in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 16th Dec 2010, 21:38
  How to add an mp3 audio file onto an mp4 video file?By Tintin11 in forum RestorationReplies: 4Last Post: 4th Nov 2010, 07:01
  Convert h.264 MP4 w/AAC 5.1 audio to AVI file w/AC3 5.1 audio for Xbox 360By ycrazyy in forum Newbie / General discussionsReplies: 6Last Post: 14th Jan 2010, 16:25
  AVI to mp4, no audio or video much faster than audioBy michaelab in forum ffmpegX general discussionReplies: 2Last Post: 21st Nov 2008, 13:48
  Converting VOB file to MP4 file. Video is perfect, audio is nonexistent.By jdfrosty in forum ffmpegX general discussionReplies: 6Last Post: 17th Jul 2007, 19:31
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
