  1. I have got a DVD from Dream Theater Chaos In Motion 2007 - 2008. I have seen in DVD menu there are (play all, song selection and audio options) "looked at the picture.
    Also, to second option "in song selection" there are tracks from video live.
    My question. How can I do my DVD to have got play all video and song selection?
  2. Ok. Can I make on a video or to I have got separately?
  3. Member DB83's Avatar
    Jul 2007
    The conventional way to do this is to create one video for each song. You then prepare a Playlist which combines each song in the order you select (DVDLabPro can automatically create a 'Play All' Playlist in the order you create the assets for the dvd.
    It can be done by having one long video with every song. But then you have to create chapter points at the entry for the individual song and exit points when the song ends (the exit point is quite an advanced technique)
    The Playlist method is the easiest way.
    Other than the programs suggested by Baldrick, Ulead DVDWorkshop2 - quite an old program now - can handle Playlists and multiple audio tracks and is quite easy to master.
