Hi, I have a client that wants a XDCAM HD 50 encoded .mxf file.. Rendering this out is not an issue, the problem that I have facing is with their audio requirements. They want the audio track to be 2 channels, 1 stereo L and 1 stereo R. Now, I don't have a problem setting up the audio with the video as per those specs, but when I render it out, the rendered file gives me 2 mono channels , and theres like 9 tracks of audio... Anyone have any idea how I can make sure that what the audio output is, is just the 2 channels of stereo L and R..? Thanks
Maybe I get this wrong, but...you said your client'd wanted the video with 2-channel audio. So L+R gives 2 channels. If you wanted stereo L and stereo R that would make 4-channel audio, because stereo already is 2-channel. And now...hail to the Flood coming over me
Das Leben ist eine Nebelwand voller Rasierklingen. (C. Bukowski) -
Audio can be fixed and then all original video and that new audio can be put into mkv format, purpose of this is to see and hear all original shoot with media devices.
ffmpeg can demultiplex your mxf:
you get video.m2v, left_audio.wav, right_audio.wav, notice how -map works within ffmpeg to get to different tracks, video is for example -map 1:0, but this is default so you do not need put it into command line if you start with itCode:ffmpeg -i video.mxf -vcodec copy -an video.m2v -map 0:1 -acodec copy -vn left_audio.wav -map 0:2 -acodec copy -vn right_audio.wav
then sox utility can make one audio from those two audio tracks:
http://www.youtube.com/watch?v=MWb3bKTUvrACode:sox -M left_audio.wav right_audio.wav stereo.wav
Or
you can just covert audio and leave original video, this way it is much easier, you can get sound from Premeiere or VLC etc. , you mux video and audio into mkv again,
if they want to edit it they would need originals though and they can view it within editor ...
Encoding a vob file to use in premiere pro
By spongela in forum Video ConversionReplies: 2Last Post: 17th Oct 2011, 18:31 -
Adobe Premiere H.264 Encoding
By Priapism in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 70Last Post: 27th Aug 2009, 02:24 -
Export DV AVIs without re-encoding in Premiere?
By moxiecat in forum EditingReplies: 1Last Post: 2nd Aug 2009, 03:04 -
Adobe Premiere CS4 + GPU H.264 Encoding
By deadrats in forum ComputerReplies: 1Last Post: 11th Dec 2008, 18:01 -
Premiere Pro encoding preset - Can't find it - Pls help!
By slinky005 in forum Video ConversionReplies: 1Last Post: 26th Sep 2008, 13:21
