I have been fighting with premiere for weeks!
All I want to do is create the FASTEST render possible for testing purposes in Premiere!
I have tested out Adobe after effects and it renders SOOO fast. If I have a movie I click 'Composition' -> 'Pre-Render'
It then creates an entry in the render queue. I then click on 'best settings' to customize them and I set to Quality = Draft and resolution = half.
I then click render and 30 seconds of video renders in like 30 seconds.
I put rendered video in media Infor and it says:
Format : AVI
Codec ID/Info : Basic Windows bitmap format. 1, 4 and 8 bpp versions are palettised. 16, 24 and 32bpp contain raw RGB samples
idth : 640 pixels
Height : 390 pixels
How can I achieve this in premiere? HEEELP PLEASE! this is so annoying. I can't stand premiere with it's 20 minute long render times!
Thanks for the response.
I was looking in premiere, but I simply cannot find them. I can't understand why they aren't there. Do I need to download a codec or something?
Help! When I render a video in Adobe After effects, theres no sound!??!?!
By Devilsadvocate in forum EditingReplies: 4Last Post: 21st Mar 2012, 10:02 -
Settings for Premiere smart render/how to tell if it's working...
By rcavanah in forum EditingReplies: 8Last Post: 14th Sep 2011, 19:20 -
Render before Exporting in Premiere Pro
By newsphotog in forum EditingReplies: 1Last Post: 29th Sep 2009, 11:39 -
Render farm for Adobe After Effects and/or Premiere?
By Mylo in forum Video ConversionReplies: 1Last Post: 21st Feb 2009, 15:46 -
Adove Encore CS4 in Oct
By ihmcjacky in forum Authoring (DVD)Replies: 1Last Post: 7th Oct 2008, 04:11
